Data order getting changed in I2C in ESP32 Arduino
umersoftwares
Postby umersoftwares » Fri Sep 27, 2024 1:36 pm
I programmed an ESP32 as an I2C slave. I was using arduino IDE to program the ESP32 and the version installed in the boards manager is 3.0.4. When I tested it with a master, the data order was incorrect on the received data. To test it at a very basic level, I wrote a piece of code where whatever the master wrote to the slave, the slave would return the double of it on the next data request. The issue is that the data is getting shifted. I receive my expected value on the second request and the first one returns the previous value (Check the master and slave outputs to understand better)
Following is the code for I2C slave
#include <Wire.h>
int receivedValue = 0;
int responseValue = 0;
  Wire.begin(0x08); // join I2C bus with address 0x08
  Wire.onReceive(receiveEvent); // register event for receiving data from master
  Wire.onRequest(requestEvent); // register event for responding to master requests
// This function is triggered when data is received from the master
void receiveEvent(int howMany) {
  if (Wire.available()) {
    receivedValue = Wire.read(); // Receive the number sent by the master
    responseValue = receivedValue * 2; // Double the value
    Serial.print("Received from master: ");
    Serial.print(receivedValue);
    Serial.print(", Prepared to send: ");
    Serial.println(responseValue);
// This function is triggered when the master requests data
void requestEvent() {
  Wire.write(responseValue); // Send the doubled value back to the master
Following is the code for I2C master
#include <Wire.h>
const int slaveAddress = 0x08; // I2C address of the slave
  Wire.begin(); // join I2C bus as master
  // Send numbers 1, 2, 3, 4, 5 in series
  for (int valueToSend = 1; valueToSend <= 5; valueToSend++) {
    sendAndReceive(valueToSend); // Send and receive for each number
    delay(1000);                 // 1-second delay between transmissions
void sendAndReceive(int valueToSend) {
  // Send the value to the slave
  Wire.beginTransmission(slaveAddress);
  Wire.write(valueToSend); // Send the number to be doubled
  Wire.endTransmission();
  delay(5000); // Small delay to ensure the slave processes the request
  // Request 1 byte back from the slave
  Wire.requestFrom(slaveAddress, 1);
    int receivedValue = Wire.read(); // Read the response from the slave
    Serial.print("Sent: ");
    Serial.print(valueToSend);
    Serial.print(", Received: ");
    Serial.println(receivedValue); // Expecting the doubled value
    Serial.println("No response from slave");
Following is the serial output on the slave
Received from master: 1, Prepared to send: 2
Received from master: 2, Prepared to send: 4
Received from master: 3, Prepared to send: 6
Received from master: 4, Prepared to send: 8
Received from master: 5, Prepared to send: 10
Following is the serial output from the master
Sent: 1, Received: 10
Sent: 2, Received: 2
Sent: 3, Received: 4
Sent: 4, Received: 6
Sent: 5, Received: 8
I suspect the issue is with the I2C slave. I uploaded this same slave code to an Arduino mega while the master was the same ESP32 and the response was correct without changing the data order.
rickyzhang
Re: Data order getting changed in I2C in ESP32 Arduino
Postby rickyzhang » Sat Jan 24, 2026 4:04 am
I encountered the same problem using Arduino UNO R2 as I2C master and ESP32 as slave.
The slave serial console print out the right order, while the master request previous value.
I even tried the suggestion from ESP32 doc: Wire.slaveWrite. But it didn't solve the problem.
However, I accidentally found that put the slaveWrite in onReceive magically solve the problem. I watch that in my oscilloscope and also confirm in the master.
Here is slave:
#include <Wire.h>
#define I2C_SLAVE_ADDR 0x55
#define SDA_PIN 16
#define SCL_PIN 17
uint8_t volatile receivedValue = 0;
  Serial.begin(9600);
  Wire.begin(I2C_SLAVE_ADDR, SDA_PIN, SCL_PIN, 0);
  Serial.println("Simple I2C Slave Ready");
  delay(100);
void receiveEvent(int numBytes) {
    Serial.print("[SLAVE] Received: 0x");
    Serial.println(receivedValue, HEX);
    uint8_t responseValue = receivedValue + 0x50;
    //Wire.write(responseValue);
    Wire.slaveWrite(&responseValue, 1);
    Serial.print("[SLAVE] Sending back: 0x");
    Serial.print(receivedValue, HEX);
    Serial.print(" + 0x50 = 0x");
    Serial.println(responseValue, HEX);
    // Clear any remaining bytes
    while (Wire.available()) {
      Wire.read();
Here is master
#include <Wire.h>
// Arduino UNO I2C pins:
// SDA: Pin A4
// SCL: Pin A5
const int SLAVE_ADDRESS = 0x55;
int counter = 1;
  Serial.begin(9600);
  Wire.begin(); // Initialize as I2C master
  Serial.println("Arduino UNO I2C Master Started");
  Serial.println("Sending counter 1-100 to slave at address 0x55");
  Serial.println("--------------------------------------------");
  if (counter <= 100) {
    // Send counter value to slave
    Wire.beginTransmission(SLAVE_ADDRESS);
    Wire.write(counter);
    delay(50); // Small delay to allow slave to process
    // Request echo back from slave
    Wire.requestFrom(SLAVE_ADDRESS, 1);
      int echo = Wire.read();
      Serial.print("[MASTER] Sent: 0x");
      Serial.print(counter, HEX);
      Serial.print(" | [SLAVE] Echo: 0x");
      Serial.println(echo, HEX);
      Serial.println(" | [SLAVE] No response");
    counter++;
    // Reset counter after reaching 100
    counter = 1;
    Serial.println("Counter reset to 1");
  delay(100); // Wait 500ms between transmissions
Users browsing this forum: Amazon [Bot], Bing [Bot], ChatGPT-User and 1 guest
