ESP32-C3 无法关闭加密。
Posted: Sun Sep 29, 2024 3:30 pm
买了3片"新"的ESP32-C3FH4,正常烧录成功,会报错:
通过添加 --force 参数后可以烧录进去,芯片日志一直是 invalid header: 0x97df56ec。
查阅官方问题,发现可以通过以下命令实现关闭加密:
但是执行后,还是有报错:
也试过其他的命令,但都是提示参数无效,只有 burn_efuse SPI_BOOT_CRYPT_CNT 能够运行,但是会出现上诉错误。
也尝试强制清理过flash,但都无效,芯片一直是加密状态。
所有命令均在下载模式中执行的:
实在找不到解决办法了,请大佬解答帮忙,感谢!
esptool.py v4.5.1
Serial port /dev/cu.usbserial-1140
Connecting....
Chip is ESP32-C3 (revision v0.3)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 10:91:a8:e3:13:30
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
A fatal error occurred: WARNING: Detected flash encryption enabled and download manual encrypt disabled.
Flashing plaintext binary may brick your device! Use --force to override the warning
espefuse --port /dev/cu.usbserial-1140 burn_efuse SPI_BOOT_CRYPT_CNTCode: Select all
espefuse.py v4.7.0
Connecting...
Detecting chip type... ESP32-C3
=== Run "burn_efuse" command ===
The efuses to burn:
from BLOCK0
- SPI_BOOT_CRYPT_CNT
Burning efuses:
- 'SPI_BOOT_CRYPT_CNT' (Enables flash encryption when 1 or 3 bits are set and disables otherwise) 0b001 -> 0b011
A fatal error occurred: SPI_BOOT_CRYPT_CNT is write-protected. Burn is not possible.
espefuse --port /dev/cu.usbserial-1140 burn_efuse FLASH_CRYPT_CNT
espefuse --port /dev/cu.usbserial-1140 set_flash_encryption_disabled
所有命令均在下载模式中执行的:
rst:0x1 (POWERON),boot:0x7 (DOWNLOAD(USB/UART0/1))
waiting for download
