disable core 1 for saving power?
cyberman54
Postby cyberman54 » Sun Jan 14, 2018 7:49 pm
Is it possible to pin all tasks to core 0 and switch off core 1 to save power?
igrr
Re: disable core 1 for saving power?
Postby igrr » Mon Jan 15, 2018 2:48 am
Yes, you can choose "Run FreeRTOS on first core only" option in menuconfig, Component config > FreeRTOS menu and build the application again. That will disable 2nd CPU and all the tasks will run on the 1st.
cyberman54
Postby cyberman54 » Mon Jan 15, 2018 9:05 pm
Thank you for your reply!
So it is possible, good to know.
But i am not using the ESP-IDF, i am using PlatformIO extension with MS Visual Studio Code. And i'm using framework Arduino for ESP32, because i need a library which has not been ported for ESP32.
Does anyone know where i can find / set the UNICORE compile option on PlatformIO IDE?
cyberman54
Postby cyberman54 » Wed Jan 17, 2018 7:18 am
I found out how to set the single core option from platformIO IDE, someone gave me the hint that this can be done with a build option:
build_flags = -D  CONFIG_FREERTOS_UNICORE
I tried it and compiled my code with this build option. It has no impact on the power consumption, not 1 mA. So i think the CPU is still running both cores.
How can i check this?
WiFive
Postby WiFive » Wed Jan 17, 2018 8:45 am
Arduino and platformio are using precompiled libs so adding that compiler option won't do anything since libesp32.a is already compiled.
cyberman54
Postby cyberman54 » Wed Jan 17, 2018 12:42 pm
Thanks for this explanation, now i understand why my change has no impact.
Which Arduino libraries fpr ESP32 should i recompile with the UNICORE build-option to get a single core cpu?
dizcza
Postby dizcza » Mon Dec 05, 2022 9:29 pm
Is it possible to disable the second core at runtime?
I have a flag in a header file that, if set, uses ULP instead of the second core.
#define ULP_ENABLE 1
#if ULP_ENABLE
// start ULP and disable core APP_CPU_NUM
#else
// use APP_CPU_NUM to perform the same task
#endif
I could perhaps issue a deep sleep on the second core (can I?) and never wake up if this flag is set, I'm not sure. Either way, deep sleep != power down, not even hibernation.
lbernstone
Postby lbernstone » Mon Dec 05, 2022 10:39 pm
The Tasmota group regularly releases framework sets for the solo chips on platformio.
https://github.com/tasmota/platform-espressif32
doragasu
Postby doragasu » Tue Nov 19, 2024 1:55 pm
Does this really disable the second core? Or will it be active but idling? I have an app running on an esp32-s3 and I'm measuring power consumption using a Power Profiler Kit II. Lowering CPU freq to 80 MHz I see a reduction in power consumption of about 4 or 5 mA, but enabling this option I see no noticeable difference. How much reduction should I expect assuming the core was previously active but idle?
Users browsing this forum: Baidu [Spider] and 2 guests
