esp32 idf LCD example "esp_lcd_panel_rgb.h" error
Gaston1980
Postby Gaston1980 » Sun Oct 06, 2024 10:49 am
Hi to all, I just start to use esp-idf IDE and tried to build the example code for the LCD and this error came out:
 fatal error: esp_lcd_panel_rgb.h: No such file or directory
   14 | #include "esp_lcd_panel_rgb.h"
why?
There is not such file in the folder and I run the idf.py menuconfig to check if selecting some data this file will be generated..but no luck. I found another thread about this issue in this forum but theres no answer either. Do I need to download this file?
Regards
Gastón
MicroController
Re: esp32 idf LCD example "esp_lcd_panel_rgb.h" error
Postby MicroController » Mon Oct 07, 2024 11:36 am
More details needed.
1. Which chip/SoC are you targeting? - The LCD-RGB panel example only works for the ESP32-S3.
2. Which example do you use?
3. How did you set up the new project with the example code?
Gaston1980
Postby Gaston1980 » Mon Oct 07, 2024 12:25 pm
Thanks for your reply, Im using esp idf 5.3 and I tried to compile the LCD example and I didn0t choose any esp32 board. I know that I need a s3 board but why this particular file is not in the folder? is it generated by building the example with the board?
gastón
MicroController
Postby MicroController » Tue Oct 08, 2024 9:44 am
"The LCD example" is not very specific. I guess you tried the rgb_panel example from https://github.com/espressif/esp-idf/tr ... herals/lcd.
No, the file is not generated. Depending on the capabilities of the target chip you're compiling for, the ESP-IDF build system does or does not add certain header and source files to the build path.
You have to set the correct target (IDF_TARGET) before starting a build, otherwise either the build will fail or it will produce a binary which won't work on the actual chip.
webwarrior007
Postby webwarrior007 » Sat Aug 30, 2025 12:04 pm
I targeted esp32S3 and also got the error. No idea how to get it to work. I tick from the config menu or adding an extension of esp_lcd that cannot be found?
Postby Sprite » Sun Aug 31, 2025 1:42 am
The esp_lcd_panel_rgb stuff only works on chips that have a parallel LCD interface. The ESP32C5 does not have that.
Users browsing this forum: Amazon [Bot], Craig_2026 and 1 guest
