Problem with Secure Download
shaftback2000
Postby shaftback2000 » Fri Oct 18, 2024 11:29 am
Hi Folks,
i have problems to download files to my esp32-s3 after activating SecureDownload and Flash encryption.
here is my Security Information
esptool.py v4.7.0
Serial port COM10
Connecting.....
Chip is ESP32-S3 in Secure Download Mode
Enabling default SPI flash mode...
Security Information:
Flags: 0x00000684 (0b11010000100)
Key Purposes: (2, 3, 0, 0, 0, 0, 12)
Chip ID: 9
API Version: 0
Secure Boot: Disabled
Flash Encryption: Enabled
SPI Boot Crypt Count (SPI_BOOT_CRYPT_CNT): 0x7
Dcache in UART download mode: Disabled
Icache in UART download mode: Disabled
JTAG: Permenantly Disabled
Hard resetting via RTS pin...
idf.py encrypted-flash monitor will lead to this message:
esptool.py v4.7.0
Serial port COM10
Connecting....
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00006fff...
Flash will be erased from 0x00010000 to 0x00101fff...
Erasing flash...
A fatal error occurred: Failed to enter Flash download mode (result was 01640000: Unknown result)
CMake Error at run_serial_tool.cmake:66 (message):
  D:/Tools/Espressif/python_env/idf5.2_py3.11_env/Scripts/python.exe;;D:/Tools/Espressif/frameworks/esp-idf-v5.2.2/components/esptool_py/esptool/esptool.py;--chip;esp32s3
  failed.
ERIAL_TOOL=D:/Tools/Espressif/python_env/idf5.2_py3.11_env/Scripts/python.exe;;D:/Tools/Espressif/frameworks/esp-idf-v5.2.2/components/esptool_py/esptool/esptool.py;--chip;esp32s3 -D SERIAL_TOOL_ARGS=--before=default_reset;--after=no_reset;--no-stub;write_flash;@encrypted_flash_args -D WORKING_DIRECTORY=D:/esp/wspace/wss_server/build -P D:/Tools/Espressif/frameworks/esp-idf-v5.2.2/components/esptool_py/run_serial_tool.cmake"
←[31mFAILED: ←[0mCMakeFiles/encrypted-flash D:/esp/wspace/wss_server/build/CMakeFiles/encrypted-flash
cmd.exe /C "cd /D D:\Tools\Espressif\frameworks\esp-idf-v5.2.2\components\esptool_py && D:\Tools\Espressif\tools\cmake\3.24.0\bin\cmake.exe -D IDF_PATH=D:/Tools/Espressif/frameworks/esp-idf-v5.2.2 -D SERIAL_TOOL=D:/Tools/Espressif/python_env/idf5.2_py3.11_env/Scripts/python.exe;;D:/Tools/Espressif/frameworks/esp-idf-v5.2.2/components/esptool_py/esptool/esptool.py;--chip;esp32s3 -D SERIAL_TOOL_ARGS=--before=default_reset;--after=no_reset;--no-stub;write_flash;@encrypted_flash_args -D WORKING_DIRECTORY=D:/esp/wspace/wss_server/build -P D:/Tools/Espressif/frameworks/esp-idf-v5.2.2/components/esptool_py/run_serial_tool.cmake"
ninja failed with exit code 1, output of the command is in the D:\esp\wspace\wss_server\build\log\idf_py_stderr_output_7684 and D:\esp\wspace\wss_server\build\log\idf_py_stdout_output_7684
How can i revert that ?
