connect ESP32-S3-WROOM-1U Antenna
tonbor
Postby tonbor » Fri Oct 18, 2024 5:33 pm
I bought ESP32-S3-WROOM-1U to use with an external antenna. But is the internal antenna connected or the ipex connected?
akasaka_spk
Re: connect ESP32-S3-WROOM-1U Antenna
Postby akasaka_spk » Sun Oct 20, 2024 11:42 pm
If I'm looking at the right module, there cannot be an internal antenna under the shield, so it's safe to assume the IPEX connector is the only way to get the signal into the module, as there is no PCB antenna trace on it.
