ESP-IDF on FreeBSD: Toolchain rejects toolchain due to crosstool-ng tagging as UNKNOWN
Posted: Sat Oct 19, 2024 8:23 am
by Drohne
With an update of port devel/xtensa-esp-elf and some own tweaks as well as with the (private) port provided of T. Sakurai (trombik) on github.com (xtensa-esp32-elf, now providing also a LLVM derived/focussed toolchain), one is able to use a decent toolchain on FreeBSD.
To some extend I'm able to utilize some of the crucial Python based tools for the convenience of using the official ESP-IDF, but not without minor tweaks.
The main problem I face is that the ESP-IDF derives a toolchain tag from the toolchain binaries via a Python script. Since the toolchain is then nailed down to a specific ESP-IDF, and the toolchain's binaries are identified as:
[... ESP-IDF v5.3 ...]
[esp-idf]: /usr/local/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc --version
==>> xtensa-esp-elf-gcc (crosstool-NG UNKNOWN) 13.2.0
Copyright (C) 2024 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
My setup is the most simplest cmake setup for a demonstration project you can imagine and simply taken from the ESP-IDF handbook, so nothing fancy, simply inlcuding the regular stuff. So, the IDF tools respond to this with (idf.py menuconfig) due to a check (/pool/home/itsme/Projects/esp-idf/tools/cmake/tool_version_check.cmake):
[rollmops]: idf.py menuconfig
Executing action: menuconfig
Running cmake in directory /pool/home/itsme/Projects/esp-dev.git/rollmops/build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DPYTHON=/usr/local/bin/python -DESP_PLATFORM=1 -DCCACHE_ENABLE=0 /pool/home/itsme/Projects/esp-dev.git/rollmops"...
-- IDF_TARGET is not set, guessed 'esp32' from sdkconfig '/pool/home/itsme/Projects/esp-dev.git/rollmops/sdkconfig'
-- Found Git: /usr/local/bin/git (found version "2.47.0")
-- The C compiler identification is GNU 14.2.0
-- The CXX compiler identification is GNU 14.2.0
-- The ASM compiler identification is GNU
-- Found assembler: /usr/local/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/local/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/local/xtensa-esp-elf/bin/xtensa-esp32-elf-g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Building ESP-IDF components for target esp32
-- Project sdkconfig file /pool/home/itsme/Projects/esp-dev.git/rollmops/sdkconfig
-- Compiler supported targets: xtensa-esp-elf
CMake Error at /pool/home/itsme/Projects/esp-idf/tools/cmake/tool_version_check.cmake:36 (message):
Tool doesn't match supported version from list ['esp-14.2.0_20240906']:
Please try to run 'idf.py fullclean' to solve it.
I have managed to build the FreeBSD port provided toolchain to include a tag, so the binary's version is correctly shown as
xtensa-esp-elf-gcc (crosstool-NG esp-14.2.0_20240906) 14.2.0
but this makes it impossible to switch between ESP-IDF v5.3 and v5.4.
The binary's identification tag is imprinted when crosstool-ng is built and is in fact the crosstool-ng version as far as I can fathom.
QUESTION:
How can I force the ESP-IDF v5.3 and/or v5.4 to bahve amnesiac on the crosstool-ng version used and therefore the binaries of the toolchain tagged for? Did I oversaw something in the ESP-IDF handbook (which is, in contrary to an earlier statement I lost here is quite good and covering really many aspects ...)?
Thank you in advance.
Re: ESP-IDF on FreeBSD: Toolchain rejects toolchain due to crosstool-ng tagging as UNKNOWN
Posted: Fri Nov 01, 2024 1:34 am
by trombik
Posted: Fri Nov 01, 2024 4:17 am
by trombik
export IDF_MAINTAINER=y
Posted: Sat Nov 02, 2024 12:01 am
by trombik
FLAVOR=idf54 is now supported.
https://github.com/trombik/xtensa-esp32 ... 84ccf2b4a2
don't use the port in the official FreeBSD ports. it's broken.
Posted: Tue Dec 24, 2024 4:27 pm
by JohnnyZ
I am experiencing the same error but with riscv32 toolchain for esp32-c3 on FreeBSD -CURRENT. It was working month ago, I didn't updated toolchain (I am using latest from tobik's github).
Error:
Tool doesn't match supported version from list ['esp-14.2.0_20241119']:
/usr/local/riscv32-esp-elf-idf54/bin/riscv32-esp-elf-gcc
I've rebuilt toolchain, tried with master and 5.4 branches, reinstalled all python and ESP things, cleaned, fullcleaned - still the same...
In my case, toolchain is not tagged unknown but still didn't work:
riscv32-esp-elf-gcc --version
riscv32-esp-elf-gcc (crosstool-NG esp-14.2.0_20240906) 14.2.0
Workaround is, as specified in previous comment:
