in search of a breakout board
edlentz
Postby edlentz » Thu Oct 24, 2024 2:52 am
I have a couple of Expressif esp32 dev boards. I want to add a W5500 lite so I don't rely on wiFi I have a terminal adapter board that I am using currently. What I am looking for is something similar but with the w5500 mounting area with traces to the esp32 pins. Does anyone know where I might get one of these boards, if they are available. I searched around Amazon but found nothing.
Ed
username
Re: in search of a breakout board
Postby username » Thu Oct 24, 2024 11:25 am
edlentz
Postby edlentz » Thu Oct 24, 2024 7:34 pm
Thanks username for the link, that is the exact W5500 I have. Maybe I didn't share what I want very well. I have a breakout board for the esp32 with terminal strips. I want an integrated board that I can attach the esp32 and the W5500 with tracing for the connections between them. I saw one on a review of the W5500 a board that had them both mounted and it looked sweet. I tied to contact the reviewer and or track down the board but to no avail.
Thanks for any ideas
username
Postby username » Fri Oct 25, 2024 12:43 am
edlentz
Postby edlentz » Fri Oct 25, 2024 3:46 pm
Ah Those look interesting. alas I already have a module and the W5500 jack. If I didn't already have what is working I would definately go for the module you suggested. I would have to rewire my setup. Would you know if that ESP32 board would work with ESP home and Home Assistant? I would need a mounting board similar to what I have so I could get the outputs to my terminal strips. I have considered creating a PCB for what I have. Not so easy so far.
horace99
Postby horace99 » Sat Oct 26, 2024 11:16 am
there are modules with ESP32 and Ethernet on board, e.g. the WT32-eth01https://github.com/egnor/wt32-eth01, the ESP32-Ethernet-Kit v1.2 https://docs.espressif.com/projects/esp ... guide.html, etc
Users browsing this forum: PetalBot and 3 guests
