I’m currently working on a PCB design that integrates the ESP32-WROOM-32UE-N8 module, but I'm facing some challenges due to incomplete or unclear technical documentation.
In the resources I've found so far, several components are listed with vague or "TBD" values, and there isn’t a clear reference on how to properly connect everything for this specific module. For example:
- Capacitors (C1, C2, C14, C15) have undefined values, and it’s not clear what values would work best with the crystal oscillator and other parts of the board.
Other components like R2 are marked as variable, depending on the PCB board, without specific recommendations.
Furthermore, I can't find any information on the USB-to-Serial interface. I’m planning to use a CP2102 or similar USB-to-Serial converter, but it’s unclear how to wire it correctly with the ESP32-WROOM-32UE.
A complete list of components needed to get the module fully operational.
Recommended values for the "TBD" components.
Detailed connection instructions, especially for integrating a USB-to-Serial converter like the CP2102.
Any help or shared resources would be greatly appreciated! Thank you in advance for your assistance.
Best regards,
Maxime
