need help with esp32-wroom-S nodemcu with ads1252 module
kriskorn
Postby kriskorn » Mon Oct 28, 2024 3:21 pm
Hi
I am new to esp32 and need help connecting an ads1252 module to my esp32, what I need are schematic diagram of pins connections and a basic sketch example.
I designed a project with esp32 to read analog signals and process them digitally that is working well, the only problem is that the 12bits of the AD of the esp32 are not enough for the varied ranges of signals that I have to measure and now I want to try with a 24bit AD converter like the ADS1252. It doesn't necessarily have to be the ADS1252 it could be some other converter that you suggest.
Thanks in advance.
horace99
Re: need help with esp32-wroom-S nodemcu with ads1252 module
Postby horace99 » Tue Oct 29, 2024 9:52 am
try a web search for ADS1252 Arduino - you will get plenty of links
in particular https://github.com/aeonSolutions/AeonLa ... no-Library
kriskorn
Postby kriskorn » Thu Oct 31, 2024 3:53 pm
Ok thanks I'm going to check it out ;)
Users browsing this forum: Semrush [Bot] and 2 guests
