ESP-IDF in VSCode and OpenOCD
haz_coder
Postby haz_coder » Tue Oct 29, 2024 12:36 pm
I have been working for a few days to get ESP-IDF working in VSCode. Followed every tutorial and video on the internet almost, but got it working now.
I have an ESP32-S3 with a dual USB (one UART and one JTAG).
I am now able to flash the module using UART, on either port.
Now I am moving to debugging.
Followed the instructions, installed the USB driver for the embedded JTAG interface, changed the interface in VSCode from UART to JTAG. And clicked flash. Not yet at the debugging. When I do, I get the attached prompt. I say yes to launch, then get the following.
Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:26)
Licensed under GNU GPL v2
For bug reports, read
C:\Users\Hassa\.espressif\tools\openocd-esp32\v0.12.0-esp32-20240318\openocd-esp32\bin\openocd.exe
*Flash]
[OpenOCD]
debug_level: 2
adapter speed: 20000 kHz
WARNING: boards/esp32-wrover.cfg is deprecated, and may be removed i
n a future release.
         If your board is ESP32-WROVER-KIT, use board/esp32-wrover-kit-1.8v.cfg instead.
Info : auto-selecting first available session tran
sport "jtag". To override use 'transport select <transport>'.
❌ Error: unable to open ftdi device with description '*', serial '*' at bus location '*'
❌ C:\Users\Hassa\.espressif\tools\openocd-esp32\v0.12.0-esp32-20240318/openocd-esp32/share/openocd/scripts/target/esp_common.cfg:9: Error:
at file "C:\Users\Hassa\.espressif\tools\openocd-esp32\v0.12.0-esp32-20240318/openocd-esp32/share/openocd/scripts/target/esp_common.cfg", line 9
For assistance with OpenOCD errors, please refer to our Troubleshooting FAQ: https://github.com/espressif/openocd-esp32/wiki/Troubleshooting-FAQ
OpenOCD Exit with non-zero error code 1
[Stopped] : OpenOCD Server
[/OpenOCD]
Flash]
Can't perform JTag flash, because OpenOCD server is not running!
Flash has finished. You can monitor with ESP-IDF: Monitor your device command
non zero exit code 1
The following Python requirements are not satisfied:
Requirement 'setuptools<71.0.1,>=21' was not met. Installed version: 75.3.0
To install the missing packages, please run "install.bat"
Diagnostic information:
    IDF_PYTHON_ENV_PATH: C:\Users\Hassa\.espressif\python_env\idf5.3_py3.11_env
    Python interpreter used: C:\Users\Hassa\.espressif\python_env\idf5.3_py3.11_env\Scripts\python.exe
Constraint file: C:\Users\Hassa\.espressif\espidf.constraints.v5.3.txt
Requirement files:
 - C:/Users/Hassa/Desktop/esp-idf/tools\requirements\requirements.core.txt
Python being checked: C:\Users\Hassa\.espressif\python_env\idf5.3_py3.11_env\Scripts\python.exe
ESP-IDF v5.3.1
Requirement files:
ESP-IDF v5.3.1
/Flash]
[SDK Configuration Editor]
---------------------------ERROR--------------------------
Requirement files:
-----------------------END OF ERROR-----------------------
ESP-IDF v5.3.1
SDK Configuration editor confserver process exited with code: 1
Then I keep getting this in the VSCode notification.
Error: non zero exit code 1 The following Python requirements are not satisfied: Requirement 'setuptools<71.0.1,>=21' was not met. Installed version: 75.3.0 To install the missing packages, please run "install.bat" Diagnostic information: IDF_PYTHON_ENV_PATH: C:\Users\Hassa\.espressif\python_env\idf5.3_py3.11_env Python interpreter used: C:\Users\Hassa\.espressif\python_env\idf5.3_py3.11_env\Scripts\python.exe Constraint file: C:\Users\Hassa\.espressif\espidf.constraints.v5.3.txt Requirement files: - C:/Users/Hassa/Desktop/esp-idf/tools\requirements\requirements.core.txt Python being checked: C:\Users\Hassa\.espressif\python_env\idf5.3_py3.11_env\Scripts\python.exe ESP-IDF v5.3.1 at ChildProcess.<anonymous> (\dist\extension.js:2:1421636) at ChildProcess.emit (node:events:519:28) at Process.ChildProcess._handle.onexit (node:internal/child_process:294:12)
I know all these are clearly why I am not able to flash with JTAG, the question is, is there a manual or step by step to fix all this. My assumption would have been that the Extension would have taken care of all of this, but clearly there is a lot of manual setup that I need to do which for the past 2 days I have been. Now I am stuck here.
For example, when I get use install.bat...where and how.
I am not an expert user, first time setting this up.
Screenshot 2024-10-29 052131.jpg (16.59 KiB) Viewed 12943 times
haz_coder
Re: ESP-IDF in VSCode and OpenOCD
Postby haz_coder » Tue Oct 29, 2024 2:59 pm
The last error I get regarding is when I try to change device target.
haz_coder
Postby haz_coder » Tue Oct 29, 2024 7:38 pm
Uninstalled everything and reinstalled everything.
Did everything in the PowerShell first. Got it working to the same point as before. OpenOCD would not work.
Did some search on this error, and pointed me to access to the USB library for the builtin JTAD in my ESP32-S3.
In Device Manager, found the JTAG USB driver, updated the windows driver, and boom, started working.
Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND
Reinstalled the VSCode extension, did everything again, and now Debug works in VSCode as well.
Always the simplest things.
rashid_20
Postby rashid_20 » Wed Feb 19, 2025 9:05 am
Hi @haz_coder, Im also facing with same issue, can you tell me how to figure it out
mhws700
Postby mhws700 » Mon Mar 10, 2025 10:30 am
Hi @rashid_20, Hi @haz_coder, could you please give some more details about the JTAG USB fix.
klaatu2
Postby klaatu2 » Mon Mar 10, 2025 8:02 pm
Did you get the JTAG OpenOCD debugger working?
What instructions in your original post are your referring to?
All my attempts have failed and typically result in the console output stops.
The board I'm using is the ESP32-S3-LCD-EV and it has two ports, one is USB the other is USB to a UART converter.
Espressif claims that the JTAG interface can be operated thru the 2-pin USB port of the ESP32-S3
https://docs.espressif.com/projects/esp ... -jtag.html
However, the instructions are, as usual, seemingly for ESP-IDF outside of VSC. Does anyone really use ESP-IDF outside of VSC?
mhws700
Postby mhws700 » Fri Mar 14, 2025 10:29 pm
The esp32c6-devkitC-1 has two usb connectors
With one flashing and monitoring is possible. The device manager shows the Siliconlabs COM port Image.
Connecting the USB cable to the other connector enables not only flashing but also debugging. The device manager show USB Serial COM
port and an USB JTAG debug unit Image
Users browsing this forum: Bing [Bot] and 0 guests
