ESP32S3 Ethernet connection with IPV6 address
fanmen1
Postby fanmen1 » Wed Oct 30, 2024 4:55 pm
Hi, I'm trying to include a IPV6 feature for MODBUS TCP/IP stack which works flawlessly with IPV4 but once I assign IPV6 address and also change the TCP/IP mode to IPV6, there is no connection establishment. Can someone point me to example initialisation for ethernet IPV6, cause I can't find one example for ethernet.
The ethernet is initialised properly and I'm able ping my device from the command prompt. However, it does not accept the modbus TCP/IP connection. I'm using ESP-IDF v5.1.5 in visual studio code.
ondrej
Re: ESP32S3 Ethernet connection with IPV6 address
Postby ondrej » Wed Nov 06, 2024 7:31 am
Users browsing this forum: DuckDuckGo [Bot], PerplexityBot, Qwantbot and 2 guests
