Summary: My ESP32 watchdog triggers after a few hours. Using the answer from the other thread, I found out the files and lines the CPUs are working on at the time of the reset.
PRO CPU: File $IDF_PATH/components/esp32/dport_panic_highint_hdl.S:181. The PRO CPU seems to be stuck in a tight loop waiting for CPU1 to finish a dport access (I might be wrong since I don't know too much about assembler):
.check_dport_access_end:
l32i a3, a2, 0
beqz a3, .check_dport_access_end
REG_READ(SPI_DATE_REG(3));Code: Select all
/* stall other cpu that this cpu is pending to access dport register start */
void IRAM_ATTR esp_dport_access_stall_other_cpu_start(void)
#ifndef CONFIG_FREERTOS_UNICORE
if (dport_core_state[0] == DPORT_CORE_STATE_IDLE
|| dport_core_state[1] == DPORT_CORE_STATE_IDLE) {
return;
BaseType_t intLvl = portENTER_CRITICAL_NESTED();
int cpu_id = xPortGetCoreID();
#ifdef DPORT_ACCESS_BENCHMARK
ccount_start[cpu_id] = XTHAL_GET_CCOUNT();
#endif
if (dport_access_ref[cpu_id] == 0) {
portENTER_CRITICAL_ISR(&g_dport_mux);
oldInterruptLevel[cpu_id]=intLvl;
dport_access_start[cpu_id] = 0;
dport_access_end[cpu_id] = 0;
if (cpu_id == 0) {
_DPORT_REG_WRITE(DPORT_CPU_INTR_FROM_CPU_3_REG, DPORT_CPU_INTR_FROM_CPU_3); //interrupt on cpu1
_DPORT_REG_WRITE(DPORT_CPU_INTR_FROM_CPU_2_REG, DPORT_CPU_INTR_FROM_CPU_2); //interrupt on cpu0
while (!dport_access_start[cpu_id]) {};
// !!! APP CPU was at the following instruction during the WDT-caused reset
REG_READ(SPI_DATE_REG(3)); //just read a APB register sure that the APB-bus is idle
dport_access_ref[cpu_id]++;
if (dport_access_ref[cpu_id] > 1) {
/* Interrupts are already disabled by the parent, we're nested here. */
portEXIT_CRITICAL_NESTED(intLvl);
#endif /* CONFIG_FREERTOS_UNICORE */
Thank you for any suggestions. I'm not deep enough into ESP32 internals to be able to solve this on my own.
