Partition Table Error In Spiffs File System
tahseenabbas52
Postby tahseenabbas52 » Tue Nov 05, 2024 1:56 pm
Hey,
I was testing spiffs example on ESP32, the original example app is working fine. No i want to deploy it along with another component is around 21MB in size, that component is working fine in another example other than spiffs. Now, when i add that module in spiffs example the error occurs that app partition is too small for binary. I changed the partition table but don't know what steps to take after that to fix the issue.
I have tried following things :
1. Tried to increase the Size in partition table like 25MB.
2. On build, logs suggested to modify serial flasher config, i changed flash size from 2M to 32MB.
3. Then i build and flashed the app on esp32 and got the following error:
E (88) flash_parts: partition 2 invalid - offset 0x10000 size 0x200000 exceeds flash chip size 0x200000
Here is the partition table
Espressif ESP32 Partition Table
Name       Type     SubType     Offset      Size     Flags
nvs          data     nvs         0x9000      0x6000
phy_init     data     phy         0xf000      0x1000
factory      app      factory     0x250000     2M
storage      data     spiffs                  1500k
Can any one provide step by step guide to solve this.
MicroController
Re: Partition Table Error In Spiffs File System
Postby MicroController » Tue Nov 05, 2024 3:08 pm
With this partition table, you set the start (Offset) of the factory partition to 25MB, but the size of that partition is still set to 2MB.
tahseenabbas52
Postby tahseenabbas52 » Wed Nov 06, 2024 5:44 am
I have already tried on 25M and i was getting following error, seems like my ESP Chip doesn't have that much flash size, but i can't figure out than how that component is working in other apps that are without spiffs.
A fatal error occurred: File storage.bin (length 1536000) at offset 28639232 will not fit in 4194304 bytes of flash. Change the --flash_size argument, or flashing address.
CMake Error at run_serial_tool.cmake:66 (message):
  C:/Espressif/python_env/idf5.3_py3.11_env/Scripts/python.exe;;C:/Espressif/frameworks/esp-idf-v5.3.1/components/esptool_py/esptool/esptool.py;--chip;esp32
  failed.
Also, i have seen some where in logs the Max Flash Size on ESP32 is 4MB, but i am totally confused then how that opencv component was working in other examples ?
