Bricked ESP32-S3
Jorgie
Bricked ESP32-S3
Postby Jorgie » Sat Nov 16, 2024 3:49 am
Hi
I have been quite happily using these devices:
https://core-electronics.com.au/esp32-s ... tired.html
However, when I went to upload a ESP IDF Example I appear to have bricked, not one but 3 devices.
How can I recover the devices?
What did I do wrong?
The code used is:
[Codebox=c file=Untitled.c]/* GPIO Example
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <inttypes.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "driver/gpio.h"
 * Brief:
 * This test code shows how to configure gpio and how to use gpio interrupt.
 * GPIO status:
 * GPIO18: output (ESP32C2/ESP32H2 uses GPIO8 as the second output pin)
 * GPIO19: output (ESP32C2/ESP32H2 uses GPIO9 as the second output pin)
 * GPIO4:  input, pulled up, interrupt from rising edge and falling edge
 * GPIO5:  input, pulled up, interrupt from rising edge.
 * Note. These are the default GPIO pins to be used in the example. You can
 * change IO pins in menuconfig.
 * Test:
 * Connect GPIO18(8) with GPIO4
 * Connect GPIO19(9) with GPIO5
 * Generate pulses on GPIO18(8)/19(9), that triggers interrupt on GPIO4/5
#define GPIO_OUTPUT_IO_0    CONFIG_GPIO_OUTPUT_0
#define GPIO_OUTPUT_IO_1    CONFIG_GPIO_OUTPUT_1
#define GPIO_OUTPUT_PIN_SEL  ((1ULL<<GPIO_OUTPUT_IO_0) | (1ULL<<GPIO_OUTPUT_IO_1))
 * Let's say, GPIO_OUTPUT_IO_0=18, GPIO_OUTPUT_IO_1=19
 * In binary representation,
 * 1ULL<<GPIO_OUTPUT_IO_0 is equal to 0000000000000000000001000000000000000000 and
 * 1ULL<<GPIO_OUTPUT_IO_1 is equal to 0000000000000000000010000000000000000000
 * GPIO_OUTPUT_PIN_SEL                0000000000000000000011000000000000000000
#define GPIO_INPUT_IO_0     CONFIG_GPIO_INPUT_0
#define GPIO_INPUT_IO_1     CONFIG_GPIO_INPUT_1
#define GPIO_INPUT_PIN_SEL  ((1ULL<<GPIO_INPUT_IO_0) | (1ULL<<GPIO_INPUT_IO_1))
 * Let's say, GPIO_INPUT_IO_0=4, GPIO_INPUT_IO_1=5
 * 1ULL<<GPIO_INPUT_IO_0 is equal to 0000000000000000000000000000000000010000 and
 * 1ULL<<GPIO_INPUT_IO_1 is equal to 0000000000000000000000000000000000100000
 * GPIO_INPUT_PIN_SEL                0000000000000000000000000000000000110000
#define ESP_INTR_FLAG_DEFAULT 0
static QueueHandle_t gpio_evt_queue = NULL;
static void IRAM_ATTR gpio_isr_handler(void* arg)
    uint32_t gpio_num = (uint32_t) arg;
    xQueueSendFromISR(gpio_evt_queue, &gpio_num, NULL);
static void gpio_task_example(void* arg)
    uint32_t io_num;
    for (;;) {
        if (xQueueReceive(gpio_evt_queue, &io_num, portMAX_DELAY)) {
            printf("GPIO[%"PRIu32"] intr, val: %d\n", io_num, gpio_get_level(io_num));
void app_main(void)
    //zero-initialize the config structure.
    gpio_config_t io_conf = {};
    //disable interrupt
    io_conf.intr_type = GPIO_INTR_DISABLE;
    //set as output mode
    io_conf.mode = GPIO_MODE_OUTPUT;
    //bit mask of the pins that you want to set,e.g.GPIO18/19
    io_conf.pin_bit_mask = GPIO_OUTPUT_PIN_SEL;
    //disable pull-down mode
    io_conf.pull_down_en = 0;
    //disable pull-up mode
    io_conf.pull_up_en = 0;
    //configure GPIO with the given settings
    gpio_config(&io_conf);
    //interrupt of rising edge
    io_conf.intr_type = GPIO_INTR_POSEDGE;
    //bit mask of the pins, use GPIO4/5 here
    io_conf.pin_bit_mask = GPIO_INPUT_PIN_SEL;
    //set as input mode
    io_conf.mode = GPIO_MODE_INPUT;
    //enable pull-up mode
    io_conf.pull_up_en = 1;
    //change gpio interrupt type for one pin
    gpio_set_intr_type(GPIO_INPUT_IO_0, GPIO_INTR_ANYEDGE);
    //create a queue to handle gpio event from isr
    gpio_evt_queue = xQueueCreate(10, sizeof(uint32_t));
    //start gpio task
    xTaskCreate(gpio_task_example, "gpio_task_example", 2048, NULL, 10, NULL);
    //install gpio isr service
    gpio_install_isr_service(ESP_INTR_FLAG_DEFAULT);
    //hook isr handler for specific gpio pin
    gpio_isr_handler_add(GPIO_INPUT_IO_0, gpio_isr_handler, (void*) GPIO_INPUT_IO_0);
    gpio_isr_handler_add(GPIO_INPUT_IO_1, gpio_isr_handler, (void*) GPIO_INPUT_IO_1);
    //remove isr handler for gpio number.
    gpio_isr_handler_remove(GPIO_INPUT_IO_0);
    //hook isr handler for specific gpio pin again
    printf("Minimum free heap size: %"PRIu32" bytes\n", esp_get_minimum_free_heap_size());
    int cnt = 0;
    while (1) {
        printf("cnt: %d\n", cnt++);
        gpio_set_level(GPIO_OUTPUT_IO_0, cnt % 2);
        gpio_set_level(GPIO_OUTPUT_IO_1, cnt % 2);
[/Codebox]
Re: Bricked ESP32-S3
Postby Sprite » Sat Nov 16, 2024 5:30 am
That board is programmed via USB, which uses GPIO19 and 20. Your example reconfigures GPIO19 as a normal GPIO, severing the USB connection. The solution is to force the board into download mode: hold the 'boot' button, press and release the 'reset' button, release the 'boot' button. You should now be able to upload a (different) program again.
Jorgie
Postby Jorgie » Sat Nov 16, 2024 6:20 am
Thank you for such a prompt and correct reply. I have unbricked two out of three. I'll try the third one again tomorrow.
Regards
Sean
