Heltec ESP W32 Kit with OLED (beginner)
candrews
Postby candrews » Tue Jan 23, 2018 1:44 am
i recently purchased two of these: MakerFocus ESP32 Development Board WiFi with 0.96inch OLED Display WIFI Kit32 Arduino Compatible CP2012 for Arduino Nodemcu https://www.amazon.com/dp/B076KJZ5QM?ref=yo_pop_ma_swf
i am a very much newbie. does anyone know where is or if there is any sample code for this product? i have managed to combine several different code samples to create a wifi scanner that outputs to the OLED. i'm not certain if what i did was best practice or just kludged together. For instance, is there a best way to talk to the OLED? i read on the datasheet there are many builtin sensors but have no clue where to begin to access them or the bluetooth or real time clock.
is there anyplace you are aware of that focuses - even slightly - on this chip ? or am i such a newbie that i need to read a lot more before i realize just how silly a question this is?
using Arduino IDE Beta. i thought since chip is new that the latest IDE would be more up to date.
BTW - if anyone is interested i would be glad to share the .ino of the scanner
thanks,
carl
zb_bamboo
Re: Heltec ESP W32 Kit with OLED (beginner)
Postby zb_bamboo » Fri Apr 13, 2018 1:15 pm
Cellie
Postby Cellie » Sat Apr 14, 2018 2:31 pm
I have made a millisecond clock poc on a similar OLED.
Shows some basic concepts.
https://gist.github.com/CelliesProjects ... 1054c409c3
You probably need to change the pin definitions.
Users browsing this forum: Google [Bot] and 3 guests
