ESP32-S3 secure boot 2 after develoment (new signing key), revoke fuse burnt?
jldesigns
Postby jldesigns » Fri Nov 22, 2024 8:04 am
Hello.
I've jumped on the project to finish up development of a ESP32-S3 device. The guy before me left a code base with a project and a script to build development and release.
We have around few dosen test devices with development signing keys. The guy assured me that it will be possible to change the key after development but only once. However I'm struggling to do it.
As You can see below It has a secure boot 2 enabled and a SECURE_BOOT_DIGEST0 for development key. However it has SECURE_BOOT_KEY_REVOKE1 and SECURE_BOOT_KEY_REVOKE2 fuse burnt. Now sure why (I don't think it was intentional).
Burnin a new SECURE_BOOT_DIGEST0 does not seems to work (i don't think it should). And using SECURE_BOOT_DIGEST1 and SECURE_BOOT_DIGEST2 seams not possible since the revoked fuses are burnt (however they seems to be R/W still).
Can anybody confirm or deny if its possible to use new signing key?
Why the SECURE_BOOT_KEY_REVOKE1 and SECURE_BOOT_KEY_REVOKE2 are burned Probably bootloader did it, but why?
This is a efuse summary of sample device used for development:
Code: efuse summary - development target.txt Select all
espefuse.py v4.7.0
Connecting....
Detecting chip type... ESP32-S3
=== Run "summary" command ===
EFUSE_NAME (Block) Description = [Meaningful Value] [Readable/Writeable] (Hex Value)
Calibration fuses:
K_RTC_LDO (BLOCK1) BLOCK1 K_RTC_LDO = 52 R/W (0b0001101)
K_DIG_LDO (BLOCK1) BLOCK1 K_DIG_LDO = -64 R/W (0b1010000)
V_RTC_DBIAS20 (BLOCK1) BLOCK1 voltage of rtc dbias20 = 80 R/W (0x14)
V_DIG_DBIAS20 (BLOCK1) BLOCK1 voltage of digital dbias20 = -100 R/W (0x99)
DIG_DBIAS_HVT (BLOCK1) BLOCK1 digital dbias when hvt = -44 R/W (0b11011)
ADC2_CAL_VOL_ATTEN3 (BLOCK1) ADC2 calibration voltage at atten3 = -24 R/W (0b100110)
TEMP_CALIB (BLOCK2) Temperature calibration data = -6.6000000000000005 R/W (0b101000010)
OCODE (BLOCK2) ADC OCode = 79 R/W (0x4f)
ADC1_INIT_CODE_ATTEN0 (BLOCK2) ADC1 init code at atten0 = -92 R/W (0x97)
ADC1_INIT_CODE_ATTEN1 (BLOCK2) ADC1 init code at atten1 = 0 R/W (0b100000)
ADC1_INIT_CODE_ATTEN2 (BLOCK2) ADC1 init code at atten2 = 92 R/W (0b010111)
ADC1_INIT_CODE_ATTEN3 (BLOCK2) ADC1 init code at atten3 = 116 R/W (0b011101)
ADC2_INIT_CODE_ATTEN0 (BLOCK2) ADC2 init code at atten0 = -196 R/W (0xb1)
ADC2_INIT_CODE_ATTEN1 (BLOCK2) ADC2 init code at atten1 = -8 R/W (0b100010)
ADC2_INIT_CODE_ATTEN2 (BLOCK2) ADC2 init code at atten2 = 64 R/W (0b010000)
ADC2_INIT_CODE_ATTEN3 (BLOCK2) ADC2 init code at atten3 = 96 R/W (0b011000)
ADC1_CAL_VOL_ATTEN0 (BLOCK2) ADC1 calibration voltage at atten0 = -16 R/W (0x84)
ADC1_CAL_VOL_ATTEN1 (BLOCK2) ADC1 calibration voltage at atten1 = 508 R/W (0x7f)
ADC1_CAL_VOL_ATTEN2 (BLOCK2) ADC1 calibration voltage at atten2 = 448 R/W (0x70)
ADC1_CAL_VOL_ATTEN3 (BLOCK2) ADC1 calibration voltage at atten3 = -24 R/W (0x86)
ADC2_CAL_VOL_ATTEN0 (BLOCK2) ADC2 calibration voltage at atten0 = -32 R/W (0x88)
ADC2_CAL_VOL_ATTEN1 (BLOCK2) ADC2 calibration voltage at atten1 = -4 R/W (0b1000001)
ADC2_CAL_VOL_ATTEN2 (BLOCK2) ADC2 calibration voltage at atten2 = -16 R/W (0b1000100)
Config fuses:
WR_DIS (BLOCK0) Disable programming of individual eFuses = 58722049 R/W (0x03800701)
RD_DIS (BLOCK0) Disable reading from BlOCK4-10 = 6 R/- (0b0000110)
DIS_ICACHE (BLOCK0) Set this bit to disable Icache = False R/W (0b0)
DIS_DCACHE (BLOCK0) Set this bit to disable Dcache = False R/W (0b0)
DIS_TWAI (BLOCK0) Set this bit to disable CAN function = False R/W (0b0)
DIS_APP_CPU (BLOCK0) Disable app cpu = False R/W (0b0)
DIS_DIRECT_BOOT (BLOCK0) Disable direct boot mode = True R/W (0b1)
UART_PRINT_CONTROL (BLOCK0) Set the default UART boot message output mode = Enable R/W (0b00)
PIN_POWER_SELECTION (BLOCK0) Set default power supply for GPIO33-GPIO37; set wh = VDD3P3_CPU R/W (0b0)
en SPI flash is initialized
PSRAM_CAP (BLOCK1) PSRAM capacity = None R/W (0b00)
PSRAM_TEMP (BLOCK1) PSRAM temperature = None R/W (0b00)
PSRAM_VENDOR (BLOCK1) PSRAM vendor = None R/W (0b00)
BLOCK_USR_DATA (BLOCK3) User data
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
BLOCK_SYS_DATA2 (BLOCK10) System data part 2 (reserved)
Flash fuses:
FLASH_TPUW (BLOCK0) Configures flash waiting time after power-up; in u = 0 R/W (0x0)
nit of ms. If the value is less than 15; the waiti
ng time is the configurable value. Otherwise; the
waiting time is twice the configurable value
FLASH_ECC_MODE (BLOCK0) Flash ECC mode in ROM = 16to18 byte R/W (0b0)
FLASH_TYPE (BLOCK0) SPI flash type = 4 data lines R/W (0b0)
FLASH_PAGE_SIZE (BLOCK0) Set Flash page size = 0 R/W (0b00)
FLASH_ECC_EN (BLOCK0) Set 1 to enable ECC for flash boot = False R/W (0b0)
FORCE_SEND_RESUME (BLOCK0) Set this bit to force ROM code to send a resume co = False R/W (0b0)
mmand during SPI boot
FLASH_CAP (BLOCK1) Flash capacity = None R/W (0b000)
FLASH_TEMP (BLOCK1) Flash temperature = None R/W (0b00)
FLASH_VENDOR (BLOCK1) Flash vendor = None R/W (0b000)
Identity fuses:
DISABLE_WAFER_VERSION_MAJOR (BLOCK0) Disables check of wafer version major = False R/W (0b0)
DISABLE_BLK_VERSION_MAJOR (BLOCK0) Disables check of blk version major = False R/W (0b0)
WAFER_VERSION_MINOR_LO (BLOCK1) WAFER_VERSION_MINOR least significant bits = 1 R/W (0b001)
PKG_VERSION (BLOCK1) Package version = 0 R/W (0b000)
BLK_VERSION_MINOR (BLOCK1) BLK_VERSION_MINOR = 2 R/W (0b010)
WAFER_VERSION_MINOR_HI (BLOCK1) WAFER_VERSION_MINOR most significant bit = False R/W (0b0)
WAFER_VERSION_MAJOR (BLOCK1) WAFER_VERSION_MAJOR = 0 R/W (0b00)
OPTIONAL_UNIQUE_ID (BLOCK2) Optional unique 128-bit ID
= b5 81 d4 fe 9f 65 5c fd b6 6b 5e ef b5 6d 19 ba R/W
BLK_VERSION_MAJOR (BLOCK2) BLK_VERSION_MAJOR of BLOCK2 = ADC calib V1 R/W (0b01)
WAFER_VERSION_MINOR (BLOCK0) calc WAFER VERSION MINOR = WAFER_VERSION_MINOR_HI = 1 R/W (0x1)
<< 3 + WAFER_VERSION_MINOR_LO (read only)
Jtag fuses:
SOFT_DIS_JTAG (BLOCK0) Set these bits to disable JTAG in the soft way (od = 7 R/W (0b111)
d number 1 means disable ). JTAG can be enabled in
HMAC module
DIS_PAD_JTAG (BLOCK0) Set this bit to disable JTAG in the hard way. JTAG = True R/W (0b1)
is disabled permanently
STRAP_JTAG_SEL (BLOCK0) Set this bit to enable selection between usb_to_jt = False R/W (0b0)
ag and pad_to_jtag through strapping gpio10 when b
oth reg_dis_usb_jtag and reg_dis_pad_jtag are equa
l to 0
Mac fuses:
MAC (BLOCK1) MAC address
= 34:85:18:52:5c:00 (OK) R/W
CUSTOM_MAC (BLOCK3) Custom MAC
= 00:00:00:00:00:00 (OK) R/W
Security fuses:
DIS_DOWNLOAD_ICACHE (BLOCK0) Set this bit to disable Icache in download mode (b = True R/W (0b1)
oot_mode[3:0] is 0; 1; 2; 3; 6; 7)
DIS_DOWNLOAD_DCACHE (BLOCK0) Set this bit to disable Dcache in download mode ( = True R/W (0b1)
boot_mode[3:0] is 0; 1; 2; 3; 6; 7)
DIS_FORCE_DOWNLOAD (BLOCK0) Set this bit to disable the function that forces c = False R/W (0b0)
hip into download mode
DIS_DOWNLOAD_MANUAL_ENCRYPT (BLOCK0) Set this bit to disable flash encryption when in d = False R/W (0b0)
ownload boot modes
SPI_BOOT_CRYPT_CNT (BLOCK0) Enables flash encryption when 1 or 3 bits are set = Enable R/W (0b001)
and disabled otherwise
SECURE_BOOT_KEY_REVOKE0 (BLOCK0) Revoke 1st secure boot key = False R/W (0b0)
SECURE_BOOT_KEY_REVOKE1 (BLOCK0) Revoke 2nd secure boot key = True R/W (0b1)
SECURE_BOOT_KEY_REVOKE2 (BLOCK0) Revoke 3rd secure boot key = True R/W (0b1)
KEY_PURPOSE_0 (BLOCK0) Purpose of Key0 = SECURE_BOOT_DIGEST0 R/- (0x9)
KEY_PURPOSE_1 (BLOCK0) Purpose of Key1 = XTS_AES_256_KEY_1 R/- (0x2)
KEY_PURPOSE_2 (BLOCK0) Purpose of Key2 = XTS_AES_256_KEY_2 R/- (0x3)
KEY_PURPOSE_3 (BLOCK0) Purpose of Key3 = USER R/W (0x0)
KEY_PURPOSE_4 (BLOCK0) Purpose of Key4 = USER R/W (0x0)
KEY_PURPOSE_5 (BLOCK0) Purpose of Key5 = USER R/W (0x0)
SECURE_BOOT_EN (BLOCK0) Set this bit to enable secure boot = True R/W (0b1)
SECURE_BOOT_AGGRESSIVE_REVOKE (BLOCK0) Set this bit to enable revoking aggressive secure = False R/W (0b0)
boot
DIS_DOWNLOAD_MODE (BLOCK0) Set this bit to disable download mode (boot_mode[3 = False R/W (0b0)
:0] = 0; 1; 2; 3; 6; 7)
ENABLE_SECURITY_DOWNLOAD (BLOCK0) Set this bit to enable secure UART download mode = False R/W (0b0)
SECURE_VERSION (BLOCK0) Secure version (used by ESP-IDF anti-rollback feat = 0 R/W (0x0000)
ure)
BLOCK_KEY0 (BLOCK4)
Purpose: SECURE_BOOT_DIGEST0
Key0 or user data
= 0b aa 7f 66 16 11 01 b1 c3 ee 6b 78 d8 ab 38 dc 20 ae fb e9 43 9e 87 ce 86 44 a7 bd 20 c7 ef fb R/-
BLOCK_KEY1 (BLOCK5)
Purpose: XTS_AES_256_KEY_1
Key1 or user data
BLOCK_KEY2 (BLOCK6)
Purpose: XTS_AES_256_KEY_2
Key2 or user data
BLOCK_KEY3 (BLOCK7)
Purpose: USER
Key3 or user data
BLOCK_KEY4 (BLOCK8)
Purpose: USER
Key4 or user data
BLOCK_KEY5 (BLOCK9)
Purpose: USER
Key5 or user data
Spi Pad fuses:
SPI_PAD_CONFIG_CLK (BLOCK1) SPI_PAD_configure CLK = 0 R/W (0b000000)
SPI_PAD_CONFIG_Q (BLOCK1) SPI_PAD_configure Q(D1) = 0 R/W (0b000000)
SPI_PAD_CONFIG_D (BLOCK1) SPI_PAD_configure D(D0) = 0 R/W (0b000000)
SPI_PAD_CONFIG_CS (BLOCK1) SPI_PAD_configure CS = 0 R/W (0b000000)
SPI_PAD_CONFIG_HD (BLOCK1) SPI_PAD_configure HD(D3) = 0 R/W (0b000000)
SPI_PAD_CONFIG_WP (BLOCK1) SPI_PAD_configure WP(D2) = 0 R/W (0b000000)
SPI_PAD_CONFIG_DQS (BLOCK1) SPI_PAD_configure DQS = 0 R/W (0b000000)
SPI_PAD_CONFIG_D4 (BLOCK1) SPI_PAD_configure D4 = 0 R/W (0b000000)
SPI_PAD_CONFIG_D5 (BLOCK1) SPI_PAD_configure D5 = 0 R/W (0b000000)
SPI_PAD_CONFIG_D6 (BLOCK1) SPI_PAD_configure D6 = 0 R/W (0b000000)
SPI_PAD_CONFIG_D7 (BLOCK1) SPI_PAD_configure D7 = 0 R/W (0b000000)
Usb fuses:
DIS_USB_OTG (BLOCK0) Set this bit to disable USB function = False R/W (0b0)
USB_EXCHG_PINS (BLOCK0) Set this bit to exchange USB D+ and D- pins = False R/W (0b0)
USB_EXT_PHY_ENABLE (BLOCK0) Set this bit to enable external PHY = False R/W (0b0)
DIS_USB_JTAG (BLOCK0) Set this bit to disable function of usb switch to = True R/W (0b1)
jtag in module of usb device
DIS_USB_SERIAL_JTAG (BLOCK0) Set this bit to disable usb device = False R/W (0b0)
USB_PHY_SEL (BLOCK0) This bit is used to switch internal PHY and extern
= internal PHY is assigned to USB Device while external PHY is assigned to USB OTG R/W (0b0)
al PHY for USB OTG and USB Device
DIS_USB_SERIAL_JTAG_ROM_PRINT (BLOCK0) USB printing = Enable R/W (0b0)
DIS_USB_SERIAL_JTAG_DOWNLOAD_MODE (BLOCK0) Set this bit to disable UART download mode through = False R/W (0b0)
USB
DIS_USB_OTG_DOWNLOAD_MODE (BLOCK0) Set this bit to disable download through USB-OTG = False R/W (0b0)
Vdd fuses:
VDD_SPI_XPD (BLOCK0) SPI regulator power up signal = False R/W (0b0)
VDD_SPI_TIEH (BLOCK0) If VDD_SPI_FORCE is 1; determines VDD_SPI voltage
= VDD_SPI connects to 1.8 V LDO R/W (0b0)
VDD_SPI_FORCE (BLOCK0) Set this bit and force to use the configuration of = False R/W (0b0)
eFuse to configure VDD_SPI
Wdt fuses:
WDT_DELAY_SEL (BLOCK0) RTC watchdog timeout threshold; in unit of slow cl = 40000 R/W (0b00)
ock cycle
Flash voltage (VDD_SPI) determined by GPIO45 on reset (GPIO45=High: VDD_SPI pin is powered from internal 1.8V LDO
GPIO45=Low or NC: VDD_SPI pin is powered directly from VDD3P3_RTC_IO via resistor Rspi. Typically this voltage is 3.3 V).
Code: sdkconfig.defaults.release.txt Select all
CONFIG_IDF_TARGET="esp32s3"
CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE=y
CONFIG_SECURE_BOOT=y
CONFIG_SECURE_FLASH_ENCRYPTION_MODE_RELEASE=y
CONFIG_SECURE_DISABLE_ROM_DL_MODE=y
CONFIG_SECURE_BOOT_SIGNING_KEY="main/security/secure_boot/rel/secure_boot_key_0.pem"
CONFIG_LOG_DEFAULT_LEVEL_ERROR=y
CONFIG_TARGET_DEVICE_RELEASE_BUILD=y
CONFIG_SECURE_BOOT_FLASH_BOOTLOADER_DEFAULT=y
CONFIG_SECURE_FLASH_ENC_ENABLED=y
CONFIG_SECURE_FLASH_ENCRYPTION_AES256=y
CONFIG_ESPTOOLPY_FLASHSIZE_16MB=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_APP_RETRIEVE_LEN_ELF_SHA=16
CONFIG_PARTITION_TABLE_OFFSET=0x10000
CONFIG_COMPILER_OPTIMIZATION_SIZE=y
CONFIG_BT_ENABLED=y
CONFIG_BT_NIMBLE_ENABLED=y
CONFIG_BT_NIMBLE_MAX_CONNECTIONS=1
CONFIG_BT_NIMBLE_MAX_BONDS=2
CONFIG_BT_NIMBLE_MAX_CCCDS=4
CONFIG_BT_NIMBLE_ATT_PREFERRED_MTU=512
CONFIG_ESP_MAIN_TASK_STACK_SIZE=4096
CONFIG_FREERTOS_PLACE_FUNCTIONS_INTO_FLASH=y
CONFIG_LWIP_TCP_SND_BUF_DEFAULT=5744
CONFIG_LWIP_TCP_WND_DEFAULT=5744
CONFIG_TARGET_DEVICE_CERT_TYPE="REL"
Code: sdkconfig.defaults.development.txt Select all
CONFIG_SECURE_BOOT_SIGNING_KEY="main/security/secure_boot/dev/secure_boot_key_0.pem"
CONFIG_LOG_DEFAULT_LEVEL_INFO=y
CONFIG_FREERTOS_USE_TRACE_FACILITY=y
CONFIG_FREERTOS_USE_STATS_FORMATTING_FUNCTIONS=y
CONFIG_FREERTOS_VTASKLIST_INCLUDE_COREID=y
CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=y
CONFIG_BT_ENABLED=y
CONFIG_TARGET_DEVICE_CERT_TYPE="DEV"
sdkconfig.development.txt
(70.8 KiB) Downloaded 72 times
(1.02 KiB) Downloaded 71 times
(1.11 KiB) Downloaded 68 times
Konstantin
Re: ESP32-S3 secure boot 2 after develoment (new signing key), revoke fuse burnt?
Postby Konstantin » Mon Nov 25, 2024 9:16 am
Hi!
At the first boot the bootloader revokes unused digest slots when unused (when the bootloader is signed only by one key). This action can be skipped if CONFIG_SECURE_BOOT_ALLOW_UNUSED_DIGEST_SLOTS is set. According to your log other digest slots, the SECURE_BOOT_KEY1 and SECURE_BOOT_KEY2, were revoked, meaning no new secure boot key can be burnt.
Yes, once BLOCK_KEY0 (BLOCK4) is burned you can not be changed it.
Users browsing this forum: PerplexityBot, Qwantbot and 6 guests
