UART 1 interrupt
Manikandan
Re: UART 1 interrupt
I suppose you want an UART event.
Try this example: examples\peripherals\uart\uart_events
Manikandan
Since the version ESP IDF 5.0 direct use of interrupts in the driver UART removed
much more convenient to use the event from the example.
if you need to actually interrupts need to go into programming registers UART that in 95% of cases does not make sense
Users browsing this forum: Amazon [Bot], ChatGPT-User and 1 guest
