ESP32 Timer changes
m8nix70
ESP32 Timer changes
Postby m8nix70 » Tue Nov 26, 2024 5:36 pm
i wrote a simple 3 phase pulse-packet-control at the beginning of the year.
I can compile it with board management 2.0.17 but now get compile errors with 3.0.7
It looks like that 4 timer-functions are obsolete or changed?
outputs.ino 362 timerAlarmWrite(hw_timer[1], TRIGGER_ANGLE_PHASE_3, false); -> error: 'timerAlarmWrite' was not declared in this scope
outputs.ino 364 timerAlarmEnable(hw_timer[1]); -> error: 'timerAlarmEnable' was not declared in this scope
outputs.ino 447 if (timerStarted(hw_timer[1])) { -> error: 'timerStarted' was not declared in this scope
outputs.ino 1085 timerAttachInterrupt(hw_timer[1], &burst_trigger_isr, false); -> error: too many arguments to function 'void timerAttachInterrupt
I hope someone can help me with new function-names, or other functions who do the same thing I wanted.
Christian
impulse_packet_control.zip
(9.99 KiB) Downloaded 132 times
lbernstone
Re: ESP32 Timer changes
Postby lbernstone » Wed Nov 27, 2024 2:41 am
m8nix70
Postby m8nix70 » Wed Nov 27, 2024 2:45 pm
Hello Ibernstone,
thank you for the migration guide link. I didn't know that one yet.
“Guide” is perhaps a somewhat exaggerated formulation.
A list of removed APIs and new APIs would be the more appropriate formulation.
There is no mention of how to replace the removed API functions with the new ones.
This is not explained in the two example applications in the latest Arduino-ESP32 Timer API either.
Anyway, I was able to solve three compiler errors.
1. the removed API:
timerAlarmWrite(hw_timer[timer_no], alarm_value, timer_reload);
replaced with new API:
timerAlarm(hw_timer[timer_no], alarm_value, timer_reload, 0);
2. the removed API:
hw_timer[timer_no] = timerBegin(timer_no, (uint16_t)(getApbFrequency() / TIME_BASE), cnt_up);
replaces with new API :
hw_timer[timer_no] = timerBegin((uint16_t)(getApbFrequency() / TIME_BASE));
3. the removed API:
timerAttachInterrupt(hw_timer[1], &burst_trigger_isr);
But I don’t found a new API function, who is telling me that a timer is running or not.
if (timerStarted(hw_timer[timer_no])) {
I also can't find a new API function to enable or disable a timer alarm
if (timerAlarmEnabled(hw_timer[timer_no])) {
  timerAlarmDisable(hw_timer[timer_no]);
So, I am very disappointed with the migration guide.
You would think that for every removed API there is a new example. It’s a joke
I changed my sample code into a single file sketch.
Once for API 2.0.17 which generates executable code and secondly API 3.0.7 with the mentioned compile errors
It powers consumer at output o1 (phase 1) with 25%, consumer at phase 2 with 50% and consumer at phase 3 with 75% power.
Please help
Chris
impulse_packet_control_3.0.7.zip
(6.6 KiB) Downloaded 132 times
impulse_packet_control_2_0_17.zip
(6.6 KiB) Downloaded 107 times
Users browsing this forum: Perplexity-User, PerplexityBot and 2 guests
