Bootlooping once the program exceeds a specific size
Posted: Mon Dec 02, 2024 10:18 am
So, my program has grown very close to the 2MB per partition size of a 4MB flash with OTA.
However, even though it technically fits, for some reason it won't boot after surpassing some specific size.
E.g. currently I have:
So then I go to my device config header and turn off a feature flag. And surprisingly it starts to work!
What I normally would do is go and disable non-essential/experimental features when I'm not using a devkit with a big (8MB/16MB) flash chip, or deprecate and delete old code. However sadly this is now production firmware and it has to fit the new code too :/
Interestingly enough, it happens on all of my 4MB ESP32 WROVER modules, no matter the origin. Experimentally I've deduced that the things go bonkers at exactly the 99.5% mark, but the actual byte count varies within that region by a margin of a few bytes.
My platformio.ini file is here: https://github.com/vladkorotnev/plasma- ... formio.ini
And the partition map is here: https://github.com/vladkorotnev/plasma- ... itions.csv
What am I doing wrong here?
Checking size .pio\build\AKI_K875\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [== ] 19.7% (used 64588 bytes from 327680 bytes)
Flash: [==========] 99.7% (used 1568765 bytes from 1572864 bytes)
CURRENT: upload_protocol = esptool
Looking for upload port...
Auto-detected: COM4
Uploading .pio\build\AKI_K875\firmware.bin
esptool.py v4.5.1
Serial port COM4
Connecting.......
Chip is ESP32-D0WD-V3 (revision v3.1)
Crystal is 40MHz
MAC: a8:42:e3:ae:9b:bc
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x00190fff...
Compressed 17536 bytes to 12202...
Writing at 0x00001000... (100 %)
Wrote 17536 bytes (12202 compressed) at 0x00001000 in 0.4 seconds (effective 334.0 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 145...
Wrote 3072 bytes (145 compressed) at 0x00008000 in 0.1 seconds (effective 446.5 kbit/s)...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 613.8 kbit/s)...
Compressed 1575056 bytes to 952743...
Writing at 0x00010000... (1 %)
Writing at 0x0018fa51... (100 %)
Wrote 1575056 bytes (952743 compressed) at 0x00010000 in 16.4 seconds (effective 768.8 kbit/s)...
Leaving...
Hard resetting via RTS pin...
--- Terminal on COM4 | 115200 8-N-1
ets Jul 29 2019 12:21:46
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13232
load:0x40080400,len:3028
entry 0x400805e4
entry 0x400805e4
... many more of the same thing ...
RAM: [== ] 19.5% (used 63940 bytes from 327680 bytes)
Flash: [==========] 98.5% (used 1549509 bytes from 1572864 bytes)
Building .pio\build\AKI_K875\firmware.bin
esptool.py v4.5.1
Creating esp32 image...
Merged 26 ELF sections
Successfully created esp32 image.
Auto-detected: COM4
esptool.py v4.5.1
Serial port COM4
Connecting....
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
Changed.
Flash will be erased from 0x00010000 to 0x0018bfff...
Wrote 17536 bytes (12202 compressed) at 0x00001000 in 0.4 seconds (effective 327.9 kbit/s)...
Wrote 3072 bytes (145 compressed) at 0x00008000 in 0.1 seconds (effective 427.2 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 615.7 kbit/s)...
Compressed 1555808 bytes to 941391...
Writing at 0x001894ca... (100 %)
Wrote 1555808 bytes (941391 compressed) at 0x00010000 in 16.1 seconds (effective 772.3 kbit/s)...
Leaving...
[ 473][I][esp32-hal-psram.c:96] psramInit(): PSRAM enabled
[ 503][I][main.cpp:289] setup(): [APL_MAIN] Hello!
[ 505][I][akizuki_k875.cpp:88] initialize(): [SWEEP] Expected pixel clock = 250000
[ 643][I][prefs.cpp:14] init_store_if_needed(): [PREF] Initialize
[ 649][E][Preferences.cpp:483] getString(): nvs_get_str len fail: v_lic NOT_FOUND
[ 656][I][yukkuri.cpp:12] Yukkuri(): [AQTK] MAC = A8:42:E3:AE:9B:BC
[ 662][I][yukkuri.cpp:13] Yukkuri(): [AQTK] License: XXX-XXX-XXX
[ 669][I][yukkuri.cpp:23] Yukkuri(): [AQTK] Init OK
[ 673][I][main.cpp:118] bringup_sound(): [APL_MAIN] Sound subsystem ready
[ 694][I][main.cpp:309] setup(): [APL_MAIN] File system mounted
[ 768][I][font.cpp:161] load_font_from_file(): [FONT] Load /disk/font/misaki_mincho.mofo
[ 802][I][font.cpp:98] load_font_from_file_handle(): [FONT] Decompressing RngZ
[ 836][I][font.cpp:145] load_font_from_file_handle(): [FONT] Decompressing BMPZ
[ 863][I][font.cpp:156] load_font_from_file_handle(): [FONT] Got font: encoding=1, glyphfmt=0, cursor=5f, invalid=25c6, w=8, h=8, range_cnt=4161, data=0x3f81d1d8, ranges=0x3f80bbd4
[ 868][I][font.cpp:161] load_font_from_file(): [FONT] Load /disk/font/jiskan16.mofo
[ 911][I][font.cpp:98] load_font_from_file_handle(): [FONT] Decompressing RngZ
[ 994][I][font.cpp:145] load_font_from_file_handle(): [FONT] Decompressing BMPZ
[ 1074][I][font.cpp:156] load_font_from_file_handle(): [FONT] Got font: encoding=1, glyphfmt=0, cursor=5f, invalid=25c6, w=16, h=16, range_cnt=6342, data=0x3f857e64, ranges=0x3f82b208
[ 1122][I][localize.cpp:97] _load_lang_map_if_needed(): [LOCA] Loaded language ID=0, Entries: 9
[ 1124][I][main.cpp:339] setup(): [APL_MAIN] setup end.
[ 1124][I][main.cpp:213] boot_task(): [APL_MAIN] LePIS-OS v5.3 is in da house now!!
... remainder of completely normal boot process ...
