Hello everybody!
Can you tell me how to get the most up-to-date data from the ADC in continuous mode? I have 2 ADC channels. I need to read data from them every 10 ms. Moreover, this data should be the most recent at the time of accessing the ADC, and not outdated from the buffer.
Here is the setup of 2 ADC channels for continuous reading at 20000 Hz sampling:
adc_continuous_handle_cfg_t adc_config = // configuring the continuous mode driver
.max_store_buf_size = 1536, // 2-frame results buffer ???
.conv_frame_size = 768, // conversion frame for 192 samples of 2 bytes for 2 channels (9.6 ms)
adc_continuous_new_handle(&adc_config, &handle_ADC); // initializing the driver
adc_continuous_config_t dig_cfg = // driver configuration
.pattern_num = 2, // for 2 ADC channels
.sample_freq_hz = 20000, // Conversion frequency 20kHz (50ms)
.conv_mode = ADC_CONV_SINGLE_UNIT_1, // conversion mode for 1 module
.format = ADC_DIGI_OUTPUT_FORMAT_TYPE1, // output format for 1 module
That's how I read the ADC every 10 msec:
adc_continuous_read(handle_ADC, result_ADC, 768, &ret_num, 3); // reading a block of 192 samples for 2 channels
As I understand it, in order to always have a fresh value, the buffer should be designed for only 1 frame, that is .max_store_buf_size should be equal to 768. But if I put 768 there, I get a kernel panic and a constant restart. It works fine only if you make a buffer of 2 frames, i.e. 1536. But in this case, I'm not sure that I'm reading exactly the most recent value, and not the previous one.
What do you recommend to me?
Current data from the ADC
Re: Current data from the ADC
struct adc_continuous_handle_cfg_t have
Without
maybe the kernel panic is related to this?
memberuint32_t flush_pool
Flush the internal pool when the pool is full.
(https://docs.espressif.com/projects/esp ... allocation).adc_continuous_handle_cfg_t::flags : set the flags that can change the driver's behavior. flush_pool: auto flush the pool when it's full.
Without
thenflush_pool=1
(https://docs.espressif.com/projects/esp ... flow-event)When the pool is full, a pool overflow event will emerge.
I tried it. With self-cleaning installed and a buffer of 768, there is a constant restart: one of the tasks gets a stack overflow. It only works with a buffer more than 2 times the size of the frame.
Users browsing this forum: Semrush [Bot] and 0 guests
