esp32c3 > gpio > mapping spi2 pins
BugSimpson
Postby BugSimpson » Tue Dec 17, 2024 9:34 am
Hello community, I'm trying in vain to get the pins from the SPI2 interface to the pins specified in the source code.
What have I forgotten?
Code: Untitled.c Select all
  gpio_pin_map_to_peripheral(6, 64);
gpio_pin_map_to_peripheral(12, 63);
gpio_pin_map_to_peripheral(13, 65);
gpio_pin_map_to_peripheral(16, 68);
gpio_set_io_mux(6, 2, 0); // gpio2 / miso (fspiq)
gpio_set_io_mux(12, 2, 0); // gpio6 / clock (fspiclk)
gpio_set_io_mux(13, 2, 0); // gpio7 / mosi (fspid)
gpio_set_io_mux(16, 2, 0); // gpio10 / chip select (fspics0)
void gpio_pin_map_to_peripheral( uint8_t _pin, uint8_t _periphSignal )
REG_WRITE( GPIO_FUNCx_OUT_SEL_CNFG_REG( _pin ), _periphSignal );
void gpio_set_io_mux(uint8_t _pin, uint8_t _func, uint8_t _inv )
REG_SET_BIT( IO_MUX_GPIOn_REG(_pin), (_func<12) | (_inv<<8));
MicroController
Re: esp32c3 > gpio > mapping spi2 pins
Postby MicroController » Tue Dec 17, 2024 12:29 pm
(_func<12)
Missing one "<"?
And MISO needs to be input.
BugSimpson
Postby BugSimpson » Wed Dec 18, 2024 4:28 pm
ohh sh** yes! thank you. its work!
