BLE ANCS Pairing Failure on ESP32 Using BLEDevice Library – Error 0x66 and Bond Loss on Repeated Connect/Disconnect
Posted: Wed Dec 18, 2024 8:55 am
Code: Untitled.cpp Select all
This behavior seems similar to an issue previously addressed in ESP-IDF, where the bonding information was being cleared during certain failure scenarios, but the smartphone retained its bond information. In ESP-IDF, this issue was resolved by modifying the bond retention logic under specific error conditions. The fix worked effectively in ESP-IDF (Reference: https://github.com/espressif/esp-idf/issues/14977)
The solution involved ensuring that bond information is not cleared when the failure reason is 0x66 (SMP timeout). In ESP-IDF, the following change was applied to prevent bond clearing for 0x66 errors:
if (sec_event.auth_cmpl.fail_reason != BTA_DM_AUTH_SMP_CONN_TOUT) {
bta_dm_remove_sec_dev_entry(bda);
This was modified to:
// bta_dm_remove_sec_dev_entry(bda);
Observations:
I added debug logs to monitor the behavior, and here are the key findings:
Before Connection:
The bond list size was logged after advertising started:
I (48502) BLE_ANCS: advertising start success
I (48502) BONDING_LIST: Bond list size after restart advertises: 3
Successful pairing was observed, with bond information intact:
I (50842) BLE_ANCS: ESP_GATTC_CONNECT_EVT
I (50842) BONDING_LIST: Bond list size after connection: 3
I (47092) BLE_ANCS: pair status = successCode: Select all
Bond information was lost after specific disconnection errors:
I (51832) BLE ANCS: pair status = fail
I (51832) BLE ANCS: fail reason = 0x66
I (51842) BONDING_LIST: Bond list size after disconnection: 2Code: Select all
Subsequent attempts failed, with persistent bond inconsistencies:
I (52902) BLE ANCS: fail reason = 0x66
I (52912) BONDING_LIST: Bond list size after disconnection: 2Questions:
How should this issue be addressed in the BLEDevice library?
Could you guide me on how to modify the bond retention logic to align with the ESP-IDF fix?
Offer to Assist:
If there’s anything else I can provide—such as additional logs, specific test cases, or further debugging details—please don’t hesitate to let me know. I’m happy to assist in any way to help address this issue.
Thank you for your time and support!
