Dear all,
Could you help me, is there an RSQRT (single precision) hardware or software function in ESP-IDF? I can't find information about it.
RSQRT on ESP32
nopnop2002
- Contact:
Re: RSQRT on ESP32
You can use these in esp-idf.
#include <stdio.h>
#include <math.h>
void app_main()
double dx = 2.0;
double da = sqrt(dx);
float fx = 2.0;
float fa = sqrt(fx);
fa = sqrtf(fx);
long double ldx = 2.0;
long double lda = sqrt(ldx);
lda = sqrtl(ldx);
alex000090
Re: RSQRT on ESP32
Thanks for your answer!
I mean is there a hardware or software implementation of "Fast inverse square root" algorithm on ESP32?
https://en.wikipedia.org/wiki/Fast_inverse_square_root
MicroController
Re: RSQRT on ESP32
What do you mean? - As soon as you copy the six lines of code into your application, there is a software implementation.is there a hardware or software implementation of "Fast inverse square root" algorithm on ESP32?
Another option is to take the assembler instruction sequences for reciprocal square root from the Xtensa Instruction Set Summary, which should be faster than using "1.0f/sqrtf(x)", i.e. a floating point sqrt PLUS a floating point division.
alex000090
Re: RSQRT on ESP32
You are absolutely right. I mean there is better software algorithm whish was incorporated into esp-idf maybe. As well as, if I'm correct, in the CPU may be hardware RSQRT command which is can be used and also incorporated into esp-idf.
Users browsing this forum: Baidu [Spider], Bing [Bot], ChatGPT-User and 0 guests
