ESP32 P4 EV Kit touch not working
Hello. Recently received the ESP32 P4 EV Kit through Aliexpress Espressif factory store. Just now, kitted up the parts after watching a YT video. Powered the LCD & main board using 2 USB type C cables. The graphics on the LCD are working fine but unable to touch any of the icons to launch the actual demos. Any suggestions on what may be wrong? The cabling looks to be snug. The touch controller is on the LCD and assuming the CTP controller is communicating through the MIPI DSI connector over I2C. Have not yet reviewed the schematics. Thanks.
Re: ESP32 P4 EV Kit touch not working
Up.
Does this EV kit require to be reflashed? If yes, from where can we source the binary / hex file to allow the touch to function?
I had the same issue, It started to work as soon as I attached the camera, too.
You can try compiling and downloading the latest project (https://github.com/espressif/esp-dev-ki ... esia_phone) to resolve the issue where the screen touch function is unavailable due to the CAMERA not being inserted.
im not sure if there is anything changed in that devkit hardware recently, but i am using devkit for about 6 months and i dont need to plug in camera to use touch screen.
All you have to do is few jumper wires and p4 bsp component.
https://components.espressif.com/compon ... ions/4.2.0
or
You can find how to wire jumper wires in docs:
https://docs.espressif.com/projects/esp ... ware-setup
I dont see reason why would you need to connect camera to use touchscreen.
or
Thanks for all the comments. Just now triple checked the cabling and no fault found.
1) How to reflash the firmware?
2) Is there a pre-compiled firmware available that will restore the touch?
Otherwise need to return this EVKIT as a DOA through Aliexpress. Thanks.
Thank you (recursively)!! The posted firmware now works with the TOUCH on my evkit.
The camera fails with a light blue screen. Logs report the camera cannot be found.
Could this be due to the v1.0 of the ESP32-P4 chip that is onboard? I recall asking for the latest silicon.
Please see below...
Connected to device: unknown ESP32-P4 (revision v1.0)
After flashing the camera test firmware, console reports:
E (93) boot_comm: Image requires chip rev <= v0.99, but chip is v1.0
E (100) boot: Factory app partition is not bootable
E (106) boot: No bootable app partitions in the partition table
ESP-ROM:esp32p4-eco2-20240710
Build:Jul 10 2024
rst:0x3 (SW_SYS_RESET),boot:0x20f (SPI_FAST_FLASH_BOOT)
SPI mode:DIO, clock div:1
load:0x4ff33ce0,len:0x17fc
load:0x4ff2abd0,len:0xcc4
load:0x4ff2cbd0,len:0x2fdc
entry 0x4ff2abda
The factory firmware boot reports:
Build:Jul 10 2024
rst:0x1 (POWERON),boot:0x20f (SPI_FAST_FLASH_BOOT)
load:0x4ff33ce0,len:0x17d8
load:0x4ff2abd0,len:0xf34
load:0x4ff2cbd0,len:0x349c
entry 0x4ff2abda
I (25) boot: ESP-IDF v5.5-dev-1377-g070c3d6b58 2nd stage bootloader
I (26) boot: compile time Jan 13 2025 15:31:41
I (26) boot: Multicore bootloader
I (29) boot: chip revision: v1.0
I (30) boot: efuse block revision: v0.1
I (34) qio_mode: Enabling default flash chip QIO
I (38) boot.esp32p4: SPI Speed : 80MHz
I (42) boot.esp32p4: SPI Mode : QIO
I (46) boot.esp32p4: SPI Flash Size : 16MB
I (50) boot: Enabling RNG early entropy source...
I (54) boot: Partition Table:
I (57) boot: ## Label Usage Type ST Offset Length
I (63) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (70) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (76) boot: 2 factory factory app 00 00 00010000 00900000
I (83) boot: 3 storage Unknown data 01 82 00910000 00400000
I (90) boot: End of partition table
I (93) esp_image: segment 0: paddr=00010020 vaddr=481c0020 size=3e5200h (4084224) map
I (725) esp_image: segment 1: paddr=003f5228 vaddr=30100000 size=00068h ( 104) load
I (727) esp_image: segment 2: paddr=003f5298 vaddr=4ff00000 size=0ad80h ( 44416) load
I (738) esp_image: segment 3: paddr=00400020 vaddr=48000020 size=1b0ee8h (1773288) map
I (1011) esp_image: segment 4: paddr=005b0f10 vaddr=4ff0ad80 size=10370h ( 66416) load
I (1024) esp_image: segment 5: paddr=005c1288 vaddr=4ff1b100 size=03ba0h ( 15264) load
I (1029) esp_image: segment 6: paddr=005c4e30 vaddr=50108080 size=0001ch ( 28) load
I (1036) boot: Loaded app from partition at offset 0x10000
I (1037) boot: Disabling RNG early entropy source...
I (1050) hex_psram: vendor id : 0x0d (AP)
I (1051) hex_psram: Latency : 0x01 (Fixed)
I (1051) hex_psram: DriveStr. : 0x00 (25 Ohm)
I (1052) hex_psram: dev id : 0x03 (generation 4)
I (1056) hex_psram: density : 0x07 (256 Mbit)
I (1061) hex_psram: good-die : 0x06 (Pass)
I (1065) hex_psram: SRF : 0x02 (Slow Refresh)
I (1070) hex_psram: BurstType : 0x00 ( Wrap)
I (1074) hex_psram: BurstLen : 0x03 (2048 Byte)
I (1079) hex_psram: BitMode : 0x01 (X16 Mode)
I (1083) hex_psram: Readlatency : 0x04 (14 cycles@Fixed)
I (1089) hex_psram: DriveStrength: 0x00 (1/1)
I (1093) MSPI DQS: tuning success, best phase id is 2
I (1270) MSPI DQS: tuning success, best delayline id is 12
I esp_psram: Found 32MB PSRAM device
I esp_psram: Speed: 200MHz
I (1465) mmu_psram: .rodata xip on psram
I (1551) mmu_psram: .text xip on psram
I (1552) hex_psram: psram CS IO is dedicated
I (1552) cpu_start: Multicore app
I (1884) esp_psram: SPI SRAM memory test OK
I (1894) cpu_start: Pro cpu start user code
I (1894) cpu_start: cpu freq: 360000000 Hz
I (1894) app_init: Application information:
I (1894) app_init: Project name: esp_brookesia_demo
I (1899) app_init: App version: 1.0.1
I (1903) app_init: Compile time: Jan 13 2025 15:31:36
I (1908) app_init: ELF file SHA256: 1c2bcc87f...
I (1912) app_init: ESP-IDF: v5.5-dev-1377-g070c3d6b58
I (1918) efuse_init: Min chip rev: v0.1
I (1922) efuse_init: Max chip rev: v1.99
I (1926) efuse_init: Chip rev: v1.0
I (1930) heap_init: Initializing. RAM available for dynamic allocation:
I (1936) heap_init: At 4FF22C90 len 00018330 (96 KiB): RAM
I (1941) heap_init: At 4FF3AFC0 len 00004BF0 (18 KiB): RAM
I (1947) heap_init: At 4FF40000 len 00040000 (256 KiB): RAM
I (1952) heap_init: At 5010809C len 00007F64 (31 KiB): RTCRAM
I (1957) heap_init: At 30100068 len 00001F98 (7 KiB): TCM
I (1962) esp_psram: Adding pool of 22912K of PSRAM memory to heap allocator
I (1969) spi_flash: detected chip: generic
I (1973) spi_flash: flash io: qio
I (1976) host_init: ESP Hosted : Host chip_ip[18]
I (2012) H_API: ESP-Hosted starting. Hosted_Tasks: prio:23, stack: 5120 RPC_task_stack: 5120
sdio_mempool_create free:23588408 min-free:23588408 lfb-def:23068672 lfb-8bit:23068672
I (2017) gpio: GPIO[18]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (2026) gpio: GPIO[19]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (2034) gpio: GPIO[14]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (2043) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (2051) gpio: GPIO[16]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (2060) gpio: GPIO[17]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (2068) H_API: ** add_esp_wifi_remote_channels **
I (2072) transport: Add ESP-Hosted channel IF[1]: S[0] Tx[0x4800d150] Rx[0x4801bd30]
I (2080) transport: Add ESP-Hosted channel IF[2]: S[0] Tx[0x4800d096] Rx[0x4801bd30]
I (2088) main_task: Started on CPU0
I (2091) main_task: Calling app_main()
I (2176) ESP32_P4_EV: Partition size: total: 3848081, used: 3217067
I (2177) main: SPIFFS mount successfully
W (2177) i2c.master: Please check pull-up resistances whether be connected properly. Otherwise unexpected behavior would happen. For more detailed information, please read docs
W (2191) i2s_common: dma frame num is adjusted to 256 to align the dma buffer with 64, bufsize = 512
W (2200) i2s_common: dma frame num is adjusted to 256 to align the dma buffer with 64, bufsize = 512
I (2212) ES8311: Work in Slave mode
I (2215) gpio: GPIO[53]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (2224) ES8311: Work in Slave mode
I (2227) gpio: GPIO[53]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (2232) I2S_IF: channel mode 0 bits:16/16 channel:2 mask:3
I (2237) I2S_IF: STD Mode 1 bits:16/16 channel:2 sample_rate:16000 mask:3
I (2243) I2S_IF: channel mode 0 bits:16/16 channel:2 mask:3
I (2249) I2S_IF: STD Mode 0 bits:16/16 channel:2 sample_rate:16000 mask:3
I (2270) Adev_Codec: Open codec device OK
I (2270) I2S_IF: channel mode 0 bits:16/16 channel:2 mask:3
I (2270) I2S_IF: STD Mode 0 bits:16/16 channel:2 sample_rate:16000 mask:3
I (2288) Adev_Codec: Open codec device OK
I (2288) LVGL: Starting LVGL task
W (2288) ledc: GPIO 26 is not usable, maybe conflict with others
I (2289) ESP32_P4_EV: MIPI DSI PHY Powered on
I (2294) ESP32_P4_EV: Install MIPI DSI LCD control panel
I (2298) ESP32_P4_EV: Install EK79007 LCD control panel
I (2303) ek79007: version: 1.0.1
I (2306) gpio: GPIO[27]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (2478) ESP32_P4_EV: Display initialized
E (2479) lcd_panel: esp_lcd_panel_swap_xy(50): swap_xy is not supported by this panel
W (2479) GT911: Unable to initialize the I2C address
I (2483) GT911: TouchPad_ID:0x39,0x31,0x31
I (2486) GT911: TouchPad_Config_Version:89
I (2490) ESP32_P4_EV: Setting LCD backlight: 100%
[WARN] [esp_brookesia_core.cpp:46](getDisplaySize): Display is not set, use default display
[INFO] [esp_brookesia_core.cpp:204](beginCore): Library version: 0.4.1
[WARN] [esp_brookesia_phone_manager.cpp:72](begin): No touch device is set, try to use default touch device
[WARN] [esp_brookesia_phone_manager.cpp:76](begin): Using default touch device(@0x0x4880a06c)
I (2593) file_iterator: File : Something.mp3
I (2599) file_iterator: File : BGM 1.mp3
I (2605) file_iterator: File : BGM 2.mp3
I (2615) file_iterator: File : For Elise.mp3
I (2621) file_iterator: File : Waka Waka.mp3
W (2623) EUI_Setting: The value of ble_en is not initialized yet, set it to default value: 0
W (2623) EUI_Setting: The value of brightness is not initialized yet, set it to default value: 20
W (2631) EUI_Setting: The value of volume is not initialized yet, set it to default value: 60
W (2639) EUI_Setting: The value of wifi_en is not initialized yet, set it to default value: 0
I (2647) bsp_extra_board: Setting volume: 60
I (2651) ESP32_P4_EV: Setting LCD backlight: 20%
I (2657) transport: Attempt connection with slave: retry[0]
I (2661) transport: Reset slave using GPIO[54]
I (2665) os_wrapper_esp: GPIO [54] configured
I (2669) gpio: GPIO[54]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (2740) file_iterator: File : weak.mp3
I (2740) file_iterator: File : excellent.mp3
I (2741) file_iterator: File : good.mp3
I (2741) file_iterator: File : normal.mp3
W (2744) Game2048: The value of score is not initialized yet, set it to default value: 0
E (2753) i2c.master: I2C transaction unexpected nack detected
E (2757) i2c.master: s_i2c_synchronous_transaction(924): I2C transaction failed
E (2764) i2c.master: i2c_master_transmit_receive(1220): I2C transaction failed
E (2771) sccb_i2c: s_sccb_i2c_transmit_receive_reg_a16v8(112): faled to transmit receive
E (2779) sc2336: Get sensor ID failed
E (2782) esp_video_init: failed to detect MIPI-CSI camera sensor with address=30
E (2789) app_video: Open video failed
E (2792) Camera: video cam open failed
E (2796) Camera: Touch not found
I (2811) app_camera_pipeline: new elements[0]:0x48f145a4, internal:1
I (2823) app_camera_pipeline: new elements[1]:0x490dc5a8, internal:1
I (2836) app_camera_pipeline: new elements[2]:0x492a45ac, internal:1
I (2848) app_camera_pipeline: new elements[3]:0x4946c5b0, internal:1
I (2848) app_camera_pipeline: new pipeline 0x48d523d0, elem_num:4
I (2849) app_camera_pipeline: new elements[0]:0x4963463c, internal:1
I (2855) app_camera_pipeline: new elements[1]:0x49634690, internal:1
I (2861) app_camera_pipeline: new elements[2]:0x496346e4, internal:1
I (2867) app_camera_pipeline: new elements[3]:0x49634738, internal:1
I (2873) app_camera_pipeline: new pipeline 0x496345b4, elem_num:4
I (2880) main_task: Returned from app_main()
I (3788) sdio_wrapper: SDIO master: Data-Lines: 4-bit Freq(KHz)[40000 KHz]
I (3788) sdio_wrapper: GPIOs: CLK[18] CMD[19] D0[14] D1[15] D2[16] D3[17] Slave_Reset[54]
I (3788) H_SDIO_DRV: Starting SDIO process rx task
I (3791) sdio_wrapper: Queues: Tx[20] Rx[20] SDIO-Rx-Mode[1]
I (3833) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (3835) gpio: GPIO[17]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
Name:
Type: SDIO
Speed: 40.00 MHz (limit: 40.00 MHz)
CSD: ver=1, sector_size=0, capacity=0 read_bl_len=0
SCR: sd_spec=0, bus_width=0
TUPLE: DEVICE, size: 3: D9 01 FF
TUPLE: MANFID, size: 4
MANF: 0092, CARD: 6666
TUPLE: FUNCID, size: 2: 0C 00
TUPLE: FUNCE, size: 4: 00 00 02 32
TUPLE: CONFIG, size: 5: 01 01 00 02 07
TUPLE: CFTABLE_ENTRY, size: 8
INDX: C1, Intface: 1, Default: 1, Conf-Entry-Num: 1
IF: 41
FS: 30, misc: 0, mem_space: 1, irq: 1, io_space: 0, timing: 0, power: 0
IR: 30, mask: 1, IRQ: FF FF
LEN: FFFF
TUPLE: END
I (3889) sdio_wrapper: Function 0 Blocksize: 512
I (3893) sdio_wrapper: Function 1 Blocksize: 512
I (3897) H_SDIO_DRV: SDIO Host operating in STREAMING MODE
I (3902) H_SDIO_DRV: generate slave intr
I (3916) transport: Received INIT event from ESP32 peripheral
I (3916) transport: EVENT: 12
I (3916) transport: EVENT: 11
I (3917) transport: capabilities: 0xd
I (3920) transport: Features supported are:
I (3924) transport: * WLAN
I (3927) transport: - HCI over SDIO
I (3930) transport: - BLE only
I (3933) transport: EVENT: 13
I (3936) transport: ESP board type is : 13
I (3940) transport: Base transport is set-up
I (3944) transport: Slave chip Id[12]
I (3948) hci_stub_drv: Host BT Support: Disabled
I (3952) H_SDIO_DRV: Received INIT event
I (3977) rpc_wrap: Received Slave ESP Init
I (4984) EUI_Setting: wifi_init done
Please see below...
Build:Jul 10 2024
entry 0x4ff2abda
Build:Jul 10 2024
entry 0x4ff2abda
Name:
Type: SDIO
IF: 41
LEN: FFFF
TUPLE: END
Can you please post a picture of how you connected the camera flat cable?
