esp32 rebooting due to weird cause
Posted: Thu Dec 26, 2024 1:58 pm
I have the rebooting esp32 problem. I can't find out the cause but I can avoid it and reproduce it again.
I have these functions to access a device using SPI and everything is well, but when I wrap these functions in
an object class the rebooting problem arises. Any experience or suggestion?
Functions
Wrapping class
Functions
void dev_init(uint8_t sck, uint8_t miso, unit8_t mosi, uint8_t ss); // called from setup function
bool dev_read(uint32_t &value); // called from loop function
SPIClass spi(VSPI); // instance for data transmission
Wrapping class
class Device
public:
Device(uint8_t bus);
void init(uint8_t sck, uint8_t miso, unit8_t mosi, uint8_t ss);
bool read(uint32 &value);
privare:
SPIClass spi;
Device::Device(uint8_t bus) : spi(bus) {...}
void Device::init(uint8_t sck, uint8_t miso, unit8_t mosi, uint8_t ss)
// idem implementation
bool Device::read(uint32 &value)
Device dev1(VSPI);;
//Device dev2(HSPI);
dev1.init(...) // called from setup
dev1.read(...); // called from loop
