I (2496) AFE_SR: Initial auido front-end, total channel: 3, mic num: 2, ref num: 1
I (2506) AFE_SR: aec_init: 1, se_init: 1, vad_init: 1
I (2516) AFE_SR: wakenet_init: 1
Guru Meditation Error: Core 0 panic'ed (StoreProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x4200c282 PS : 0x00060830 A0 : 0x8200b14c A1 : 0x3fca4d00
--- 0x4200c282: esp_aec3_hps16fft_init at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/acoustic_echo_cancellation/esp_aec3_hps16fft.c:89
A2 : 0x00000000 A3 : 0x00000200 A4 : 0x00000800 A5 : 0x00000003
A6 : 0x00000814 A7 : 0x00000002 A8 : 0x00000400 A9 : 0x3fca4ce0
A10 : 0x00000000 A11 : 0x00000001 A12 : 0x00000400 A13 : 0x3fca4d10
A14 : 0x3fca4cf0 A15 : 0x00000401 SAR : 0x00000018 EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000020 LBEG : 0x400570e8 LEND : 0x400570f3 LCOUNT : 0x00000000
--- 0x400570e8: memset in ROM
0x400570f3: memset in ROM
Backtrace: 0x4200c27f:0x3fca4d00 0x4200b149:0x3fca4d30 0x420099ba:0x3fca4d60 0x4037c935:0x3fca4df0
--- 0x4200c27f: esp_aec3_hps16fft_init at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_processor/acoustic_echo_cancellation/esp_aec3_hps16fft.c:87
0x4200b149: afe_create_from_config at /home/sunxiangyu/workspace/esp_sr_lib/components/esp_audio_front_end/esp_afe_sr.c:275
0x420099ba: App_Speech_Task at /home/esp/esp32/testesps3/build/../components/application/app_speech/app_speech.c:329
0x4037c935: vPortTaskWrapper at /home/esp/esp32/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:134
ELF file SHA256: cac034c0e
Rebooting...
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x2b (SPI_FAST_FLASH_BOOT)
Saved PC:0x40375a3c
--- 0x40375a3c: esp_restart_noos at /home/esp/esp32/esp-idf/components/esp_system/port/soc/esp32s3/system_internal.c:159
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3810,len:0x178c
load:0x403c9700,len:0x4
load:0x403c9704,len:0xcbc
load:0x403cc700,len:0x2d98
entry 0x403c9914
I (31) boot: ESP-IDF v5.2 2nd stage bootloader
I (31) boot: compile time Jan 1 2025 13:46:49
esp32s3语音识别 函数 afe_data = afe handle->create from config(&afe config);报错,是啥原因?
bugdisappear
Re: esp32s3语音识别 函数 afe_data = afe handle->create from config(&afe config);报错,是啥原因?
你好,你解决了吗?我是启用了中文库导致的复位
