Code: Untitled.c Select all
/* WiFi station Example
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#define SCAN_CHANNEL_1 1
#define SCAN_CHANNEL_13 13
#define SCAN_CHANNEL_36 36 // 5G信道
#define SCAN_CHANNEL_48 48 // 5G信道
#define PROBE_COUNT 3
#define SCAN_INTERVAL_MS 5000
#define PROBE_REQ_HEAD_LEN 24
#define SSID_IE_LEN 2
#define SUPPORTED_RATES_LEN 8
#define DS_PARAM_LEN 3
#define FRAME_CONTROL_PROBE_REQ 0x0040 // 正确的 Probe Request 帧控制值
static const char *TAG = "wifi station";
static void send_probe_req_task(void *pvParameters)
uint8_t probe_req_frame_2g[200] = {0};
uint8_t probe_req_frame_5g[200] = {0};
int cur_len_2g = 0;
int cur_len_5g = 0;
// 构造2.4G probe request基本帧
// Frame Control
probe_req_frame_2g[cur_len_2g++] = 0x40; // 帧控制字段
probe_req_frame_2g[cur_len_2g++] = 0x00;
// Duration
// Destination Address (broadcast)
memset(&probe_req_frame_2g[cur_len_2g], 0xFF, 6);
cur_len_2g += 6;
// Source Address
uint8_t mac_addr[6];
esp_wifi_get_mac(WIFI_IF_STA, mac_addr);
memcpy(&probe_req_frame_2g[cur_len_2g], mac_addr, 6);
cur_len_2g += 6;
// BSSID
cur_len_2g += 6;
// Sequence Control
// 2.4G SSID
// 2.4G Supported rates
probe_req_frame_2g[cur_len_2g++] = 0x01;
probe_req_frame_2g[cur_len_2g++] = 0x04;
probe_req_frame_2g[cur_len_2g++] = 0x82; // 1 Mbps
probe_req_frame_2g[cur_len_2g++] = 0x84; // 2 Mbps
probe_req_frame_2g[cur_len_2g++] = 0x8B; // 5.5 Mbps
probe_req_frame_2g[cur_len_2g++] = 0x96; // 11 Mbps
int total_len_2g = cur_len_2g;
// Frame Control
probe_req_frame_5g[cur_len_5g++] = 0x40; // 帧控制字段
probe_req_frame_5g[cur_len_5g++] = 0x00;
// Duration
memset(&probe_req_frame_5g[cur_len_5g], 0xFF, 6);
cur_len_5g += 6;
memcpy(&probe_req_frame_5g[cur_len_5g], mac_addr, 6);
cur_len_5g += 6;
// BSSID (broadcast)
cur_len_5g += 6;
// Sequence Control
// SSID
probe_req_frame_5g[cur_len_5g++] = 0x00; // Element ID: SSID
probe_req_frame_5g[cur_len_5g++] = 0x00; // Length: 0 (Broadcast)
// Supported Rates (5G基本速率)
probe_req_frame_5g[cur_len_5g++] = 0x01; // Element ID: Supported Rates
probe_req_frame_5g[cur_len_5g++] = 0x08; // Length
probe_req_frame_5g[cur_len_5g++] = 0x0C; // 6 Mbps
probe_req_frame_5g[cur_len_5g++] = 0x18; // 9 Mbps
probe_req_frame_5g[cur_len_5g++] = 0x30; // 12 Mbps
probe_req_frame_5g[cur_len_5g++] = 0x60; // 18 Mbps
probe_req_frame_5g[cur_len_5g++] = 0x6c; // 24 Mbps
probe_req_frame_5g[cur_len_5g++] = 0x12; // 36 Mbps
probe_req_frame_5g[cur_len_5g++] = 0x24; // 48 Mbps
probe_req_frame_5g[cur_len_5g++] = 0x48; // 54 Mbps
int total_len_5g = cur_len_5g;
while (1) {
// 2.4G 信道1发送
ESP_ERROR_CHECK(esp_wifi_set_channel(SCAN_CHANNEL_1, WIFI_SECOND_CHAN_NONE));
vTaskDelay(pdMS_TO_TICKS(20));
for (int i = 0; i < PROBE_COUNT; i++) {
esp_err_t err = esp_wifi_80211_tx(WIFI_IF_STA, probe_req_frame_2g, total_len_2g, false);
if (err == ESP_OK) {
ESP_LOGI(TAG, "Successfully sent 2.4G probe request %d/%d on channel 1", i + 1, PROBE_COUNT);
vTaskDelay(pdMS_TO_TICKS(100));
// 5G 信道36发送
ESP_ERROR_CHECK(esp_wifi_set_channel(SCAN_CHANNEL_36, WIFI_SECOND_CHAN_NONE));
uint8_t primary;
wifi_second_chan_t second;
ESP_ERROR_CHECK(esp_wifi_get_channel(&primary, &second));
ESP_LOGI(TAG, "Current channel: primary=%d, secondary=%d", primary, second);
esp_err_t err = esp_wifi_80211_tx(WIFI_IF_STA, probe_req_frame_5g, total_len_5g, false);
ESP_LOGI(TAG, "Successfully sent 5G probe request %d/%d on channel 36", i + 1, PROBE_COUNT);
// ... 其他信道的发送逻辑类似 ...
vTaskDelay(pdMS_TO_TICKS(SCAN_INTERVAL_MS));
static void wifi_init_sta(void)
esp_netif_t *sta_netif = esp_netif_create_default_wifi_sta();
assert(sta_netif);
// 简化 WiFi 配置
wifi_config_t wifi_config = {
.sta = {
.scan_method = WIFI_FAST_SCAN,
.bssid_set = 0,
.listen_interval = 0,
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config));
// 设置 WiFi 模式并启动
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
ESP_ERROR_CHECK(esp_wifi_start());
// 禁用省电模式
ESP_ERROR_CHECK(esp_wifi_set_ps(WIFI_PS_NONE));
// 确保监控模式正确设置
wifi_promiscuous_filter_t filter = {
.filter_mask = WIFI_PROMIS_FILTER_MASK_MGMT // 只过滤管理帧
ESP_ERROR_CHECK(esp_wifi_set_promiscuous_filter(&filter));
ESP_ERROR_CHECK(esp_wifi_set_promiscuous(true)); // 启用混杂模式
// 设置发送功率
int8_t power = 8; // 设置适中的发送功率
ESP_ERROR_CHECK(esp_wifi_set_max_tx_power(power));
// // 确保在信道 1
// ESP_ERROR_CHECK(esp_wifi_set_channel(SCAN_CHANNEL_1, WIFI_SECOND_CHAN_NONE));
// 查看当前WiFi频段模式
wifi_band_mode_t mode;
ESP_ERROR_CHECK(esp_wifi_get_band_mode(&mode));
ESP_LOGI(TAG, "Current WiFi band mode: %d", mode);
// 如果需要指定频段,可以这样设置:
// ESP_ERROR_CHECK(esp_wifi_set_band_mode(WIFI_BAND_MODE_2G)); // 仅2.4G
// ESP_ERROR_CHECK(esp_wifi_set_band_mode(WIFI_BAND_MODE_5G)); // 仅5G
// ESP_ERROR_CHECK(esp_wifi_set_band_mode(WIFI_BAND_MODE_AUTO)); // 自动(默认)
// 创建发送任务
xTaskCreate(send_probe_req_task, "probe_req_task", 4096, NULL, 5, NULL);
void app_main(void)
//Initialize NVS
ESP_ERROR_CHECK(ret);
ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
wifi_init_sta();
如上是程序源代码,其中2G的报文能够正常抓取到,5G的报文无法正常抓取。5G的probe request报文是根据芯片自身扫描行为发送的报文构造的相同报文。
ESP-IDF版本为v5.4.0
