Failed to set target esp32s3: non zero exit code 2
Adding "set-target"'s dependency "fullclean" to list of commands with default set of options.
Executing action: fullclean
Build directory 'D:\esp-adf\esp-adf\examples\speech_recognition\wwe\build' not found. Nothing to clean.
Executing action: set-target
Set Target to: esp32s3, new sdkconfig will be created.
Running cmake in directory D:\esp-adf\esp-adf\examples\speech_recognition\wwe\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DPYTHON=D:\Espressif\python_env\idf5.3_py3.11_env\Scripts\python.exe -DESP_PLATFORM=1 -DIDF_TARGET=esp32s3 -DCCACHE_ENABLE=0 D:\esp-adf\esp-adf\examples\speech_recognition\wwe"...
-- Found Git: D:/Espressif/tools/idf-git/2.44.0/cmd/git.exe (found version "2.44.0.windows.1")
-- The C compiler identification is GNU 13.2.0
-- The CXX compiler identification is GNU 13.2.0
-- Found assembler: D:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20240530/xtensa-esp-elf/bin/xtensa-esp32s3-elf-gcc.exe
-- Check for working C compiler: D:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20240530/xtensa-esp-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped
-- Check for working CXX compiler: D:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20240530/xtensa-esp-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped
-- Building ESP-IDF components for target esp32s3
Dependencies lock doesn't exist, solving dependencies.
NOTICE: Skipping optional dependency: espressif/esp_hosted
NOTICE: Skipping optional dependency: espressif/esp_wifi_remote
CMake Error at D:/Espressif/frameworks/esp-idf-v5.3/tools/cmake/build.cmake:552 (message):
ERROR: Error during request
URL: https://components-file.espressif.com/c ... ghttp.json
Status code: 403 Forbidden
D:/Espressif/frameworks/esp-idf-v5.3/tools/cmake/project.cmake:710 (idf_build_process)
CMakeLists.txt:10 (project)
..-- Configuring incomplete, errors occurred!
See also "D:/esp-adf/esp-adf/examples/speech_recognition/wwe/build/CMakeFiles/CMakeOutput.log".
cmake failed with exit code 1, output of the command is in the D:\esp-adf\esp-adf\examples\speech_recognition\wwe\build\log\idf_py_stderr_output_27020 and D:\esp-adf\esp-adf\examples\speech_recognition\wwe\build\log\idf_py_stdout_output_27020
