ESP_MODEM - pppos_client_main_c in C++ problems
Posted: Sun Jan 12, 2025 11:35 pm
by FrankJensen
Hi Forum.
I have got the pppos_client example included with esp_modem up running in C, so that is nice :-)
But I want to include this into another project written in cpp. That is giving me some grey hairs. I have tried all kind of approaches, but I can not get it do compile correctly. I am using cxx_include/esp_modem_api.hpp and cxx_include/esp_modem_netif.hpp, but is seems that there are some differences, and some functions seems to miss declarations. The functions are there, but as far as I can see, they are not declaired anywhere - eg esp_modem_send_sms function.
This is my list of compile errors. Can someone point me to a direction, how to solve this?
lib/MyModem/MyModem.cpp: In function 'void on_ppp_changed(void*, esp_event_base_t, int32_t, void*)':
lib/MyModem/MyModem.cpp:85:21: error: 'NETIF_PPP_ERRORUSER' was not declared in this scope
   85 |     if (event_id == NETIF_PPP_ERRORUSER) {
lib/MyModem/MyModem.cpp:87:33: error: invalid conversion from 'void*' to 'esp_netif_t**' {aka 'esp_netif_obj**'} [-fpermissive]
   87 |         esp_netif_t **p_netif = event_data;
      |                                 void*
lib/MyModem/MyModem.cpp: In function 'void on_ip_event(void*, esp_event_base_t, int32_t, void*)':
lib/MyModem/MyModem.cpp:108:39: error: invalid conversion from 'int' to 'esp_netif_dns_type_t' [-fpermissive]
  108 |         esp_netif_get_dns_info(netif, 0, &dns_info);
      |                                       int
In file included from components/esp_modem/include/esp_modem_c_api_types.h:10,
                 from components/esp_modem_usb_dte/include/esp_modem_usb_c_api.h:9,
                 from lib/MyModem/MyModem.cpp:10:
C:/Users/Frank.FUTURELIGHT/.platformio/packages/framework-espidf/components/esp_netif/include/esp_netif.h:751:79: note:   initializing argument 2 of 'esp_err_t esp_netif_get_dns_info(esp_netif_t*, esp_netif_dns_type_t, esp_netif_dns_info_t*)'
  751 | esp_err_t esp_netif_get_dns_info(esp_netif_t *esp_netif, esp_netif_dns_type_t type, esp_netif_dns_info_t *dns);
lib/MyModem/MyModem.cpp:110:39: error: invalid conversion from 'int' to 'esp_netif_dns_type_t' [-fpermissive]
  110 |         esp_netif_get_dns_info(netif, 1, &dns_info);
      |                                       int
In file included from C:/Users/Frank.FUTURELIGHT/.platformio/packages/framework-espidf/components/esp_driver_uart/include/driver/uart.h:9,
                 from components/esp_modem/include/esp_modem_config.h:9,
                 from components/esp_modem/include/esp_modem_c_api_types.h:9:
lib/MyModem/MyModem.cpp: In member function 'void MyModem::_begin()':
lib/MyModem/MyModem.cpp:138:48: error: 'NETIF_PPP_STATUS' was not declared in this scope
  138 |     ESP_ERROR_CHECK(esp_event_handler_register(NETIF_PPP_STATUS, ESP_EVENT_ANY_ID, &on_ppp_changed, NULL));
C:/Users/Frank.FUTURELIGHT/.platformio/packages/framework-espidf/components/esp_common/include/esp_err.h:116:30: note: in definition of macro 'ESP_ERROR_CHECK'
  116 |         esp_err_t err_rc_ = (x);                                        \
lib/MyModem/MyModem.cpp:207:13: error: 'esp_modem_sms_txt_mode' was not declared in this scope; did you mean 'esp_modem_set_mode'?
  207 |         if (esp_modem_sms_txt_mode(dce, true) != ESP_OK || esp_modem_sms_character_set(dce) != ESP_OK) {
      |             esp_modem_set_mode
lib/MyModem/MyModem.cpp:207:60: error: 'esp_modem_sms_character_set' was not declared in this scope
lib/MyModem/MyModem.cpp:216:15: error: 'esp_modem_send_sms' was not declared in this scope; did you mean 'esp_modem_set_apn'?
  216 |         err = esp_modem_send_sms(dce, tlf, "Hej Carsten. Dette er en besked sendt fra ESP32 via modem :-)");
      |               esp_modem_set_apn
lib/MyModem/MyModem.cpp:281:15: error: 'esp_modem_get_imsi' was not declared in this scope; did you mean 'esp_modem_get_mode'?
  281 |         err = esp_modem_get_imsi(dce, imsi);
      |               esp_modem_get_mode
*** [.pio\build\ESP32-S3-DevKitC-1U-N8R2\lib3d7\MyModem\MyModem.o] Error 1
Re: ESP_MODEM - pppos_client_main_c in C++ problems
Posted: Mon Jan 13, 2025 9:47 am
by FrankJensen
Adding this to my project, solves the problem. But is that really the right way?
Code: Untitled.cpp Select all
extern "C" esp_err_t esp_modem_send_sms(esp_modem_dce_t *dce_wrap, const char *number, const char *message);
extern "C" esp_err_t esp_modem_sms_txt_mode(esp_modem_dce_t *dce_wrap, bool txt);
extern "C" esp_err_t esp_modem_sms_character_set(esp_modem_dce_t *dce_wrap);
extern "C" esp_err_t esp_modem_get_imsi(esp_modem_dce_t *dce_wrap, char *p_imsi);
extern "C" esp_err_t esp_modem_get_signal_quality(esp_modem_dce_t *dce_wrap, int *rssi, int *ber);
/** @brief PPP event base */
ESP_EVENT_DECLARE_BASE(NETIF_PPP_STATUS);
#define NETIF_PP_PHASE_OFFSET (0x100)
#define NETIF_PPP_INTERNAL_ERR_OFFSET (0x200)
typedef enum {
NETIF_PPP_ERRORNONE = 0, /* No error. */
NETIF_PPP_ERRORPARAM = 1, /* Invalid parameter. */
NETIF_PPP_ERROROPEN = 2, /* Unable to open PPP session. */
NETIF_PPP_ERRORDEVICE = 3, /* Invalid I/O device for PPP. */
NETIF_PPP_ERRORALLOC = 4, /* Unable to allocate resources. */
NETIF_PPP_ERRORUSER = 5, /* User interrupt. */
NETIF_PPP_ERRORCONNECT = 6, /* Connection lost. */
NETIF_PPP_ERRORAUTHFAIL = 7, /* Failed authentication challenge. */
NETIF_PPP_ERRORPROTOCOL = 8, /* Failed to meet protocol. */
NETIF_PPP_ERRORPEERDEAD = 9, /* Connection timeout */
NETIF_PPP_ERRORIDLETIMEOUT = 10, /* Idle Timeout */
NETIF_PPP_ERRORCONNECTTIME = 11, /* Max connect time reached */
NETIF_PPP_ERRORLOOPBACK = 12, /* Loopback detected */
NETIF_PPP_PHASE_DEAD = NETIF_PP_PHASE_OFFSET + 0,
NETIF_PPP_PHASE_MASTER = NETIF_PP_PHASE_OFFSET + 1,
NETIF_PPP_PHASE_HOLDOFF = NETIF_PP_PHASE_OFFSET + 2,
NETIF_PPP_PHASE_INITIALIZE = NETIF_PP_PHASE_OFFSET + 3,
NETIF_PPP_PHASE_SERIALCONN = NETIF_PP_PHASE_OFFSET + 4,
NETIF_PPP_PHASE_DORMANT = NETIF_PP_PHASE_OFFSET + 5,
NETIF_PPP_PHASE_ESTABLISH = NETIF_PP_PHASE_OFFSET + 6,
NETIF_PPP_PHASE_AUTHENTICATE = NETIF_PP_PHASE_OFFSET + 7,
NETIF_PPP_PHASE_CALLBACK = NETIF_PP_PHASE_OFFSET + 8,
NETIF_PPP_PHASE_NETWORK = NETIF_PP_PHASE_OFFSET + 9,
NETIF_PPP_PHASE_RUNNING = NETIF_PP_PHASE_OFFSET + 10,
NETIF_PPP_PHASE_TERMINATE = NETIF_PP_PHASE_OFFSET + 11,
NETIF_PPP_PHASE_DISCONNECT = NETIF_PP_PHASE_OFFSET + 12,
NETIF_PPP_CONNECT_FAILED = NETIF_PPP_INTERNAL_ERR_OFFSET + 0,
} esp_netif_ppp_status_event_t;
