Move libmain bss into external ram?
Posted: Thu Jan 16, 2025 5:24 pm
by expresspotato
So does anyone know how to move the bss segment of a component (in this case main) into external ram? I seem to need to use a linker fragment, but not sure what extra directives or steps are needed, because I'm unfamiliar with the linker fragment.
Per-archive contributions to ELF file:
            Archive File DRAM .data & 0.bss .ext_ram.bss .rtc_noinit .rtc.text .noinit IRAM0 .text & 0.vectors ram_st_total Flash .text & .rodata & .rodata_noload & .appdesc flash_total
                 libbt.a       4774       0        51347           0         0       0        1658           0        57779      503966    139630                0          0      650028
               libmain.a       2805    5881            0           1         0    1024       18193           0        27904       95248     85160                0          0      202431
So I tried to mimic the linker fragment found in idf, for another component, but it didn't seem to work...
CMakeLists.txt (in the main folder)
idf_component_register(
	SRCS
		"main.c"
	INCLUDE_DIRS
		"include"
		"ulp/include"
	LDFRAGMENTS "app.lf"
And a Linker Fragment of:
[scheme:default]
entries:
    if ESP_ALLOW_BSS_SEG_EXTERNAL_MEMORY = y:
        bss -> extern_ram
    else:
        bss -> dram0_bss
[mapping:main]
archive: libmain.a
entries:
    * (bss);
But the results remain the same...
Re: Move libmain bss into external ram?
Posted: Thu Jan 16, 2025 6:20 pm
by MicroController
https://docs.espressif.com/projects/esp ... config-bss
Additional data can be moved from the internal BSS segment to external RAM by applying the macro EXT_RAM_BSS_ATTR to any static declaration (which is not initialized to a non-zero value).
Posted: Thu Jan 16, 2025 7:57 pm
by expresspotato
Hey, thanks for your reply.
The page says "It is also possible to place the BSS section of a component or a library to external RAM using linker fragment scheme extram_bss."
Rather than go at it variable by variable, it seems like I could place the entire segment there with the correct linker fragment directive.
I don't know enough of how the linker works to come up with anything meaningful.
