ESP32 pinned Core "CPU reeboot"
Posted: Tue Jan 28, 2025 10:14 am
Hello everyone,
I'm new here and I have a problem using the two cores of the ESP32 Dev Module.
I want to create project were one of the two cores is exclusively for one scpecific task which i will program by my self.
Using the Arduino IDE (2.3.4) I have set "Events Run On: "Core 0" " and "Arduino Run On: "Core 0" ". I set those to core 0 since esp-now, which I'm planning to use later on, and stuff runs natively on core 0 and my hope is that core 1 is then completely free.
My final application shall be an PID controller with 10-1000 Hz bandwith, so i need the complete cpu power of one core and it shall not be interrupted by any other task or event etc.
Testing my approach i testet the core zero in the main loop (arduino loop) and no all is fine.
Here is wher my problem is. Testing "task0function" to check if core 1 runs correctely i have like 5 second where there is no problem and the serial.print is as expected, but periodically every 5 to 10 second there is this error:
I tried putting in some load in the task and delay etc. nothing changes and the cpu gets rebooted...
I've tried a lot and searched the documentation and the web a few hours now aked GPT but couldn'T solve the issue.
Here is my code:
I appreciate every help and comment.
Task0 runs on Core: 1
Task0 runsE (10217) task_wdt: Task watchdog got triggered. The following tasks/users did not reset the watchdog in time:
E (10217) task_wdt: - IDLE0 (CPU 0)
E (10217) task_wdt: Tasks currently running:
E (10217) task_wdt: CPU 0: loopTask
E (10217) task_wdt: CPU 1: IDLE1
E (10217) task_wdt: Aborting.
E (10217) task_wdt: Print CPU 0 (current core) backtrace
Rebooting...
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:4832
load:0x40078000,len:16460
load:0x40080400,len:4
load:0x40080404,len:3504
entry 0x400805cc
Here is my code:
// create ESP32 RTOS tasks (RTOS - RealTimeOperatingSystem)
TaskHandle_t Task0;
void setup() {
Serial.begin(115200); //setting baudrate
// RTOS setting:
// RTOS Task0 (core 1):
xTaskCreatePinnedToCore(
task0function, /* Function to implement the task */
"Task0", /* Name of the task */
10000, /* Stack size in words */
NULL, /* Task input parameter */
1, /* Priority of the task */
&Task0, /* Task handle. */
1); /* Core where the task does run */
void loop() {
// Print the core ID where the main loop is running
// Serial.print("Main Loop running on Core: ");
// Serial.println(xPortGetCoreID());
// Task0 (core 1):
void task0function(void *pvParameter) {
while (1) {
// task debugging start: -----------------------------------------------------------------------------------
// // Print the core ID where the main loop is running
Serial.print("Task0 runs on Core: ");
// // Monitor stack and heap usage
// Serial.print("Task0 Stack High Water Mark: ");
// Serial.println(uxTaskGetStackHighWaterMark(NULL)); // gives the minimum of unused stack memory
// Serial.print("Free Heap: ");
// Serial.println(esp_get_free_heap_size()); // gives the ammount of unallocated heap memory
vTaskDelay(10 / portTICK_PERIOD_MS);
// task debugging end: -----------------------------------------------------------------------------------
}Thanks
