Trying QR Reader with Esp32-cam
lill211
Postby lill211 » Sun Feb 02, 2025 4:14 am
Hi. I'm trying to make a QR reader and a web server at the same time, same esp32. It's possible?
The code runs good, the web server works but QR reader doesn't. I think that void QRCodeReader isn't starting but I don't understand what is wrong.
Code: Untitled.cpp Select all
#include "esp_camera.h"
#include <WiFi.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "quirc.h"
#define CAMERA_MODEL_AI_THINKER
#include "camera_pins.h"
TaskHandle_t QRCodeReader_Task;
const char *ssid = "c";
const char *password = "mecatronica";
void startCameraServer();
void setupLedFlash(int pin);
struct QRCodeData
  bool valid;
  int dataType;
  uint8_t payload[1024];
  int payloadLen;
struct quirc *q = NULL;
uint8_t *image = NULL;
camera_fb_t * fb = NULL;
struct quirc_code code;
struct quirc_data data;
quirc_decode_error_t err;
struct QRCodeData qrCodeData;
String QRCodeResult = "";
  Serial.setDebugOutput(true);
  Serial.println();
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  Serial.println("Empezando configuracion...");
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sccb_sda = SIOD_GPIO_NUM;
  config.pin_sccb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.frame_size = FRAMESIZE_UXGA;
  config.pixel_format = PIXFORMAT_JPEG;  // for streaming
  //config.pixel_format = PIXFORMAT_RGB565; // for face detection/recognition
  config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
  config.fb_location = CAMERA_FB_IN_PSRAM;
  config.jpeg_quality = 12;
  config.fb_count = 1;
  if (config.pixel_format == PIXFORMAT_JPEG) {
    if (psramFound()) {
      config.jpeg_quality = 10;
      config.fb_count = 2;
      config.grab_mode = CAMERA_GRAB_LATEST;
      // Limit the frame size when PSRAM is not available
      config.frame_size = FRAMESIZE_SVGA;
      config.fb_location = CAMERA_FB_IN_DRAM;
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera fallo con error 0x%x", err);
    ESP.restart();
  sensor_t * s = esp_camera_sensor_get();
  s->set_framesize(s, FRAMESIZE_QVGA);
  Serial.println("Configuracion exitosa.");
  Serial.println();
  xTaskCreatePinnedToCore(
             QRCodeReader,          /* Task function. */
             "QRCodeReader_Task",   /* name of task. */
             10000,                 /* Stack size of task */
             NULL,                  /* parameter of the task */
             0,                     /* priority of the task */
             &QRCodeReader_Task,    /* Task handle to keep track of created task */
             0);                    /* pin task to core 0 */
   delay(100);
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1);        // flip it back
    s->set_brightness(s, 1);   // up the brightness just a bit
    s->set_saturation(s, -2);  // lower the saturation
  WiFi.begin(ssid, password);
  WiFi.setSleep(false);
  Serial.print("WiFi connecting");
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  Serial.println("' to connect");
  delay(1);
void QRCodeReader( void * pvParameters ){
  Serial.println("Ready.");
  while(1){
      q = quirc_new();
      if (q == NULL){
        Serial.print("No se pueden leer.\r\n");
        continue;
      fb = esp_camera_fb_get();
      if (!fb)
        Serial.println("La camara esta fallando.");
        continue;
      quirc_resize(q, fb->width, fb->height);
      image = quirc_begin(q, NULL, NULL);
      memcpy(image, fb->buf, fb->len);
      quirc_end(q);
      int count = quirc_count(q);
      if (count > 0) {
        quirc_extract(q, 0, &code);
        err = quirc_decode(&code, &data);
        if (err){
          Serial.println("Decodificacion fallida.");
          QRCodeResult = "Decoding FAILED";
          Serial.printf("Decodificacion exitosa:\n");
          dumpData(&data);
        Serial.println();
      esp_camera_fb_return(fb);
      fb = NULL;
      image = NULL;
      quirc_destroy(q);
void dumpData(const struct quirc_data *data)
  Serial.printf("Resultado del QR: %s\n", data->payload);
  QRCodeResult = (const char *)data->payload;
lbernstone
Re: Trying QR Reader with Esp32-cam
Postby lbernstone » Sun Feb 02, 2025 11:11 pm
Loop should have a huge delay (-1 aka UINT32_MAX) rather than essentially no delay. loop has a higher priority (1) than your task (0), so it is starving your process.
Users browsing this forum: Google [Bot], PerplexityBot and 2 guests
