False errors of version 5.4
Posted: Fri Feb 07, 2025 7:58 am
I upgraded to 5.4 and noticed this oddity: if you close the idf with an open project, then the next time you run it, the compiler goes crazy - it says in the console window that everything is OK, there are no errors, but in the problems window there are a lot of errors, and there are also errors in the program text. But once you close the project, restart the ide, and then reopen the project and compile, everything miraculously becomes OK. Here are some screenshots.
