ESP32S3 FSM ULP Code Question
dmydmy
Postby dmydmy » Tue Feb 11, 2025 3:08 pm
Hi all,
I have a question regarding my ESP32S3 FSM ULP program. This one here works, when I periodically read out address 130 in the Arduino code I can see the counter increasing
const ulp_insn_t ulp_prog[] = {
    M_LABEL(0),
    I_MOVI(R1, 130),
    I_LD(R0, R1, 0),
    I_ADDI(R0, R0, 1),
    I_ST(R0, R1, 0),
    M_BX(0)
However, if want to run the counter up to 100 and then enter an infinite loop the counter stops at 1. why?
    M_LABEL(0),
    I_MOVI(R1, 130),
    I_LD(R0, R1, 0),
    I_ADDI(R0, R0, 1),
    I_ST(R0, R1, 0),
    I_BL(3, 100),
    M_LABEL(3),
    M_BX(3),
    M_BX(0)
Why doesn't it branch to M_BX(0) when R0 is less than 100, increment the counter by, repeat until R0 = 100 and then do an infinite loop M_LABEL(3), M_BX(3)?
For reference, here's the entire Arduino code:
#include "esp32s3/ulp.h"
#include "ulp_common.h"
// Define the ULP program
    M_LABEL(0),
    I_MOVI(R1, 130),
    I_LD(R0, R1, 0),
    I_ADDI(R0, R0, 1),
    I_ST(R0, R1, 0),
    I_BL(3, 100),
    M_LABEL(3),
    M_BX(3),
    M_BX(0)
  // Initialize ULP
  size_t prog_size = sizeof(ulp_prog) / sizeof(ulp_insn_t);
  ESP_ERROR_CHECK(ulp_process_macros_and_load(0, ulp_prog, &prog_size));
  // Start ULP program
  ESP_ERROR_CHECK(ulp_run(0));
  // Initialize counter to 0
  RTC_SLOW_MEM[130] =  0;
  // Read counter value
  uint32_t counter = RTC_SLOW_MEM[130];
  Serial.printf("Counter value: %ld\n", counter);
  delay(1000);  // Wait for 1 second before next read
Thanks a lot in advance!
dmy
dmydmy
Re: ESP32S3 FSM ULP Code Question
Postby dmydmy » Thu Feb 13, 2025 11:33 am
Found the solution.
M_LABEL(),
does NOT count as an instruction. So it needs to be
I_BL(2, 100),
for the code to work.
