运行volc_rtc Demo时说话没有回应
312394539@qq.com
Postby 312394539@qq.com » Tue Feb 18, 2025 1:50 am
程序运行启动,可以正常输出欢迎语
硬件使用官方推荐ESP32S3 Korvo-2,Demo已经跑通。
使用的IDF版本 5.3.1
I (27) boot: ESP-IDF v5.3.1-dirty 2nd stage bootloader
I (27) boot: compile time Feb 17 2025 16:17:49
I (27) boot: Multicore bootloader
I (30) boot: chip revision: v0.2
I (34) qio_mode: Enabling default flash chip QIO
I (39) boot.esp32s3: Boot SPI Speed : 80MHz
I (44) boot.esp32s3: SPI Mode : QIO
I (49) boot.esp32s3: SPI Flash Size : 16MB
I (54) boot: Enabling RNG early entropy source...
I (59) boot: Partition Table:
I (63) boot: ## Label Usage Type ST Offset Length
I (70) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (78) boot: 1 phy_init RF data 01 01 0000d000 00001000
I (85) boot: 2 factory factory app 00 00 00010000 00300000
I (92) boot: 3 model Unknown data 01 82 00310000 0040e000
I (100) boot: 4 spiffs_data Unknown data 01 82 0071e000 00010000
I (108) boot: End of partition table
I (112) esp_image: segment 0: paddr=00010020 vaddr=3c170020 size=4f140h (323904) map
I (169) esp_image: segment 1: paddr=0005f168 vaddr=3fc9f900 size=00eb0h ( 3760) load
I (170) esp_image: segment 2: paddr=00060020 vaddr=42000020 size=16274ch (1451852) map
I (395) esp_image: segment 3: paddr=001c2774 vaddr=3fca07b0 size=0703ch ( 28732) load
I (401) esp_image: segment 4: paddr=001c97b8 vaddr=40378000 size=17834h ( 96308) load
I (430) boot: Loaded app from partition at offset 0x10000
I (430) boot: Disabling RNG early entropy source...
I (442) octal_psram: vendor id : 0x0d (AP)
I (442) octal_psram: dev id : 0x02 (generation 3)
I (442) octal_psram: density : 0x03 (64 Mbit)
I (447) octal_psram: good-die : 0x01 (Pass)
I (452) octal_psram: Latency : 0x01 (Fixed)
I (457) octal_psram: VCC : 0x01 (3V)
I (462) octal_psram: SRF : 0x01 (Fast Refresh)
I (468) octal_psram: BurstType : 0x01 (Hybrid Wrap)
I (474) octal_psram: BurstLen : 0x01 (32 Byte)
I (480) octal_psram: Readlatency : 0x02 (10 cycles@Fixed)
I (486) octal_psram: DriveStrength: 0x00 (1/1)
I (492) MSPI Timing: PSRAM timing tuning index: 5
I (496) esp_psram: Found 8MB PSRAM device
I (501) esp_psram: Speed: 80MHz
I (505) cpu_start: Multicore app
I (794) esp_psram: SPI SRAM memory test OK
I (803) cpu_start: Pro cpu start user code
I (803) cpu_start: cpu freq: 240000000 Hz
I (803) app_init: Application information:
I (806) app_init: Project name: volc_rtc
I (811) app_init: App version: v2.7-54-gb669c7a4-dirty
I (817) app_init: Compile time: Feb 17 2025 16:16:58
I (823) app_init: ELF file SHA256: dcf53c331...
I (828) app_init: ESP-IDF: v5.3.1-dirty
I (833) efuse_init: Min chip rev: v0.0
I (838) efuse_init: Max chip rev: v0.99
I (843) efuse_init: Chip rev: v0.2
I (848) heap_init: Initializing. RAM available for dynamic allocation:
I (855) heap_init: At 3FCAED40 len 0003A9D0 (234 KiB): RAM
I (861) heap_init: At 3FCE9710 len 00005724 (21 KiB): RAM
I (867) heap_init: At 600FE100 len 00001EE8 (7 KiB): RTCRAM
I (874) esp_psram: Adding pool of 8192K of PSRAM memory to heap allocator
I (882) spi_flash: detected chip: gd
I (885) spi_flash: flash io: qio
W (890) ADC: legacy driver is deprecated, please migrate to `esp_adc/adc_oneshot.h`
I (898) sleep: Configure to isolate all GPIO pins in sleep state
I (904) sleep: Enable automatic switching of GPIO sleep configuration
I (912) main_task: Started on CPU0
I (932) esp_psram: Reserving pool of 32K of internal memory for DMA/internal allocations
I (932) main_task: Calling app_main()
I (942) main: Initialize board peripherals
I (942) PERIPH_SPIFFS: Partition size: total: 52961, used: 12299
I (942) AUDIO_THREAD: The esp_periph task allocate stack on internal memory
W (952) i2c_bus_v2: I2C master handle is NULL, will create new one
I (962) gpio: GPIO[17]| InputEn: 1| OutputEn: 1| OpenDrain: 1| Pullup: 1| Pulldown: 0| Intr:0
I (972) gpio: GPIO[18]| InputEn: 1| OutputEn: 1| OpenDrain: 1| Pullup: 1| Pulldown: 0| Intr:0
I (982) DRV8311: ES8311 in Slave mode
I (992) gpio: GPIO[48]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1002) ES7210: ES7210 in Slave mode
I (1012) ES7210: Enable ES7210_INPUT_MIC1
I (1012) ES7210: Enable ES7210_INPUT_MIC2
I (1012) ES7210: Enable ES7210_INPUT_MIC3
W (1022) ES7210: Enable TDM mode. ES7210_SDP_INTERFACE2_REG12: 2
I (1022) ES7210: config fmt 60
I (1022) AUDIO_HAL: Codec mode is 3, Ctrl:1
I (1042) pp: pp rom version: e7ae62f
I (1042) net80211: net80211 rom version: e7ae62f
I (1052) wifi:wifi driver task: 3fcc39ac, prio:23, stack:6656, core=0
I (1052) wifi:wifi firmware version: ccaebfa
I (1052) wifi:wifi certification version: v7.0
I (1052) wifi:config NVS flash: enabled
I (1052) wifi:config nano formating: disabled
I (1062) wifi:Init data frame dynamic rx buffer num: 32
I (1062) wifi:Init static rx mgmt buffer num: 5
I (1072) wifi:Init management short buffer num: 32
I (1072) wifi:Init static tx buffer num: 16
I (1072) wifi:Init tx cache buffer num: 32
I (1082) wifi:Init static tx FG buffer num: 2
I (1082) wifi:Init static rx buffer size: 1600
I (1092) wifi:Init static rx buffer num: 16
I (1092) wifi:Init dynamic rx buffer num: 32
I (1092) wifi_init: rx ba win: 16
I (1102) wifi_init: accept mbox: 6
I (1102) wifi_init: tcpip mbox: 32
I (1112) wifi_init: udp mbox: 6
I (1112) wifi_init: tcp mbox: 6
I (1112) wifi_init: tcp tx win: 5760
I (1122) wifi_init: tcp rx win: 5760
I (1122) wifi_init: tcp mss: 1440
I (1132) wifi_init: WiFi/LWIP prefer SPIRAM
I (1132) wifi_init: WiFi IRAM OP enabled
I (1142) wifi_init: WiFi RX IRAM OP enabled
W (1142) wifi:Password length matches WPA2 standards, authmode threshold changes from OPEN to WPA2
I (1152) wifi:Set ps type: 1, coexist: 0
I (1152) phy_init: phy_version 680,a6008b2,Jun 4 2024,16:41:10
I (1292) wifi:mode : sta (a0:85:e3:fd:72:8c)
I (1292) wifi:enable tsf
W (1292) PERIPH_WIFI: WiFi Event cb, Unhandle event_base:WIFI_EVENT, event_id:43
I (1622) wifi:new:<1,0>, old:<1,0>, ap:<255,255>, sta:<1,0>, prof:1, snd_ch_cfg:0x0
I (1622) wifi:state: init -> auth (0xb0)
I (1632) wifi:state: auth -> assoc (0x0)
I (1642) wifi:state: assoc -> run (0x10)
I (1652) wifi:connected with Xiaomi_974E, aid = 1, channel 1, BW20, bssid = 90:fb:5d:58:31:93
I (1652) wifi:security: WPA2-PSK, phy: bgn, rssi: -9
I (1652) wifi:pm start, type: 1
I (1662) wifi:dp: 1, bi: 102400, li: 3, scale listen interval from 307200 us to 307200 us
I (1662) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 25000, mt_pti: 0, mt_time: 10000
I (1672) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (1682) wifi:<ba-add>idx:0 (ifx:0, 90:fb:5d:58:31:93), tid:0, ssn:0, winSize:64
W (1692) PERIPH_WIFI: WiFi Event cb, Unhandle event_base:WIFI_EVENT, event_id:4
I (2692) esp_netif_handlers: sta ip: 192.168.31.126, mask: 255.255.255.0, gw: 192.168.31.1
I (2692) PERIPH_WIFI: Got ip:192.168.31.126
I (2692) audio processor: Create audio pipeline for audio player
I (2692) audio processor: Create audio player audio stream
I (2702) audio processor: Register all elements to playback pipeline
I (2712) audio processor: Link playback element together raw-->audio_decoder-->i2s_stream-->[codec_chip]
E (2722) gpio: gpio_install_isr_service(502): GPIO isr service already installed
E (2732) DISPATCHER: exe first list: 0x0
I (2732) DISPATCHER: dispatcher_event_task is running...
I (9592) RTC_HTTP_UTILS: context.result.code: 200, context.result.response: {"code": 200, "msg": "", "data": {"room_id": "G711Ac9b33c9886f1451fa36e937b76288bc4", "uid": "userc9b33c9886f1451fa36e937b76288bc4", "app_id": "676407e94a995500ffa9581b", "token": "001676407e94a995500ffa9581beQBqYDkACBizZwi7tWclAEc3MTFBYzliMzNjOTg4NmYxNDUxZmEzNmU5MzdiNzYyODhiYzQkAHVzZXJjOWIzM2M5ODg2ZjE0NTFmYTM2ZTkzN2I3NjI4OGJjNAUAAAAIu7VnAQAIu7VnAgAIu7VnAwAIu7VnBAAIu7VnIADfRfwakxGadMwgtG5xpgrsbIxww5MBHSlCkYmPLkBtJQ=="}}
1970-01-01 00:00:08.827 [E] VolcEngineRTCLite.c:105 ****************** HELLO BOOKA (676407e94a995500ffa9581b)(1.56.001.58)(6059fcf26792a8820bc81f13662979d531e5504d) ********************
1970-01-01 00:00:08.842 [E] Cache.c:270 operation returned status code: 0x00000009
1970-01-01 00:00:08.856 [E] ThreadPool.c:92 coreid 1 set 1 stack_size 8192 priority 5
I (9662) audio processor: recorder_pipeline_open
I (9662) audio processor: Create audio pipeline for recording
I (9672) audio processor: Create player audio stream
I (9682) audio processor: Register all player elements to audio pipeline
I (9682) audio processor: Link all player elements to audio pipeline
I (9692) audio processor: player_pipeline_open
I (9692) audio processor: Create audio pipeline for playback
I (9702) audio processor: Create playback audio stream
I (9712) audio_stream_7210: Create g711a decoder
I (9712) audio processor: Register all elements to playback pipeline
I (9722) audio processor: ENBALE_AUDIO_STREAM_DUAL_MIC
I (9722) audio processor: Link playback element together raw-->audio_decoder-->rsp-->i2s_stream-->[codec_chip]
I (9752) audio processor: player pipe start running
I (9752) volc_rtc: start join room
1970-01-01 00:00:09.113 [E] RoomImplX.c:167 operation returned status code: 0x52000057
I (9922) CODEC_ELEMENT_HELPER: The element is 0x3c21f7e0. The reserve data 2 is 0x0.
1970-01-01 00:00:09.300 [E] Cache.c:309 operation returned status code: 0x00000009
1970-01-01 00:00:09.305 [E] RoomImplX.c:167 operation returned status code: 0x52000057
1970-01-01 00:00:09.307 [E] LiteHttp.c:641 ID 1462728266 E_LOGIC : NO need keepAlive
1970-01-01 00:00:09.315 [E] RoomImplX.c:167 operation returned status code: 0x52000057
1970-01-01 00:00:09.440 [E] RoomImplX.c:167 operation returned status code: 0x52000057
1970-01-01 00:00:09.649 [E] RoomImplX.c:167 operation returned status code: 0x52000057
1970-01-01 00:00:09.769 [E] RoomImplX.c:167 operation returned status code: 0x52000057
1970-01-01 00:00:10.035 [E] rx_net_delay_manager.c:1130
I (10842) volc_rtc: join channel success G711Ac9b33c9886f1451fa36e937b76288bc4 elapsed 228 ms now 228 ms
I (10842) volc_rtc: join room success
I (10842) volc_rtc: remote user joined G711Ac9b33c9886f1451fa36e937b76288bc4:voiceChat_userc9b33c9886f1451fa36e937b76288bc4_1739790350
I (10852) MODEL_LOADER: The storage free size is 22784 KB
1970-01-01 00:00:10.059 [E] EngineImplX.c:103 callback pEngineImplX->eventHandler.on_user_joined used too many times 16
I (10872) MODEL_LOADER: The partition size is 4152 KB
I (10882) MODEL_LOADER: Successfully load srmodels
I (10892) RECORDER_SR: The first wakenet model: wn9_hilexin
I (10892) AFE_SR: afe interface for speech recognition
I (10902) AFE_SR: AFE version: SR_V220727
I (10912) AFE_SR: Initial auido front-end, total channel: 3, mic num: 2, ref num: 1
I (10912) AFE_SR: aec_init: 1, se_init: 1, vad_init: 1
I (10922) AFE_SR: wakenet_init: 1
1970-01-01 00:00:10.258 [E] rx_net_audio_jitterbuffer.c:1266
1970-01-01 00:00:10.260 [E] rx_net_audio_jitterbuffer.c:1190
1970-01-01 00:00:10.261 [E] rx_net_delay_manager.c:1130
1970-01-01 00:00:10.264 [E] rx_net_delay_manager.c:1130
1970-01-01 00:00:10.269 [E] Counter.c:90 AudioRecevied fps 0
MC Quantized wakenet9: wakenet9_v1h24_嗨,乐鑫_3_0.608_0.615, tigger:v3, mode:2, p:0, (Sep 4 2024 11:49:31)
I (11202) AFE_SR: wake num: 3, mode: 0, (Sep 4 2024 11:49:31)
I (11202) main_task: Returned from app_main()
1970-01-01 00:00:10.648 [E] EngineImplX.c:242 callback pEngineImplX->eventHandler.on_audio_data used too many times 5
1970-01-01 00:00:11.009 [E] Counter.c:90 AudioRecevied fps 32
1970-01-01 00:00:11.186 [E] EngineImplX.c:242 callback pEngineImplX->eventHandler.on_audio_data used too many times 6
1970-01-01 00:00:11.347 [E] EngineImplX.c:242 callback pEngineImplX->eventHandler.on_audio_data used too many times 4
1970-01-01 00:00:12.016 [E] Counter.c:90 AudioRecevied fps 49
1970-01-01 00:00:12.046 [E] EngineImplX.c:242 callback pEngineImplX->eventHandler.on_audio_data used too many times 4
1970-01-01 00:00:12.199 [E] EngineImplX.c:242 callback pEngineImplX->eventHandler.on_audio_data used too many times 4
1970-01-01 00:00:12.786 [E] EngineImplX.c:242 callback pEngineImplX->eventHandler.on_audio_data used too many times 6
1970-01-01 00:00:13.007 [E] Counter.c:90 AudioRecevied fps 48
1970-01-01 00:00:13.566 [E] EngineImplX.c:242 callback pEngineImplX->eventHandler.on_audio_data used too many times 5
1970-01-01 00:00:13.739 [E] EngineImplX.c:242 callback pEngineImplX->eventHandler.on_audio_data used too many times 4
1970-01-01 00:00:14.018 [E] Counter.c:90 AudioRecevied fps 48
1970-01-01 00:00:14.325 [E] EngineImplX.c:242 callback pEngineImplX->eventHandler.on_audio_data used too many times 5
1970-01-01 00:00:15.017 [E] Counter.c:90 AudioRecevied fps 53
1970-01-01 00:00:15.147 [E] EngineImplX.c:242 callback pEngineImplX->eventHandler.on_audio_data used too many times 5
1970-01-01 00:00:15.204 [E] EngineImplX.c:242 callback pEngineImplX->eventHandler.on_audio_data used too many times 4
一直有提示,callback pEngineImplX->eventHandler.on_audio_data used too many times 4
