Unable to Flash ESP32-CAM due to Serial Communication Issue
Posted: Thu Feb 27, 2025 9:39 am
by farzadblack
Dear Espressif Support,
I hope this message finds you well. I am facing an issue while attempting to flash my ESP32-CAM board using the esptool. Despite following all the necessary steps and troubleshooting suggestions from your documentation, I am unable to successfully connect to the device.
Here are the details of the issue:
Board: ESP32-CAM
Problem: When I try to connect to the board using esptool, I get the following error:
COM7 failed to connect: Failed to connect to ESP32: Invalid head of packet (0x00): Possible serial noise or corruption.
I’ve tried different baud rates, rechecked the wiring, and ensured that GPIO0 is connected to GND during boot.
Steps already taken:
Verified USB cable and port (COM7)
Rechecked GPIO0 connection and reset button usage
Tried with different baud rates (9600, 74880, 115200)
Used different USB-to-serial adapters
Erased flash using esptool with no success
Additional Info: The board powers on but fails to enter flash mode. Serial output displays corrupted characters when connected.
I would appreciate any guidance or troubleshooting steps you can provide. I would be happy to provide additional information if necessary.
Thank you for your time and assistance!
Best regards,
Re: Unable to Flash ESP32-CAM due to Serial Communication Issue
Posted: Fri Feb 28, 2025 4:21 pm
by lbernstone
You must hold gpio0 to ground while programming. If there is not a button, you will need to wire the pin to ground while programming. If you open serial monitor and set it to 115200, you need to see "waiting for download" on the monitor in order to program.
