ZGP project doesn't detect device
Thoos_96
Postby Thoos_96 » Sat Mar 01, 2025 5:20 pm
Hi everyone,
I recently bought an SR-ZGP2801K4-DIM-S Zigbee Green Power switch (solar-powered), and I would like to connect it to my ESP32-H2 device. I’m trying to use the sample project from the ESP Zigbee SDK:
🔗 ESP Zigbee Green Power Sample Project
So far, I have set up my ESP32-H2 and flashed the example, but I’m unsure how to properly pair the SR-ZGP2801K4-DIM-S with it. I’ve tried pressing and holding the switch buttons for 10 seconds, then pressing it once, holding it for 10 seconds again to enter pairing mode, but I don’t see any logs indicating that it’s being detected.
I believe i flashed the code right because i have the following logs on my terminal :
I (450) gpio: GPIO[9]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:4
I (450) ESP_ZGP_COMBO: Deferred driver initialization successful
I (460) ESP_ZGP_COMBO: Device started up in non factory-reset mode
I (470) ESP_ZGP_COMBO: Device rebooted
I (1070) ESP_ZGP_COMBO: Network(0x4cd9) is open for 180 seconds
Does anyone have experience with pairing Zigbee Green Power devices with ESP32-H2? Any guidance on troubleshooting or specific configurations required in the sample project would be greatly appreciated!
Thanks in advance! 😊
fbedon
Re: ZGP project doesn't detect device
Postby fbedon » Fri Apr 11, 2025 6:17 am
HI Thoos_96, hi Everyone,
What example did you set?
I’m trying to do the same thing you did with a ESP32-C6 and a Schneider ZBRT2 switch.
At the moment the only positive result is obtained with a NTX dongle OM15020 JN5169, I can see all Zigbee GP traffic :)
Who can help us with the green power use of ESP32 H2 and C6 cards?
Regards
Fred
fbedon
Postby fbedon » Mon Apr 14, 2025 1:59 pm
Hi everyone,
OK you tried with the program esp-zigbee-gpc, but this example is not really a sniffer, it expects a Zigbee LAN or something equivalent.
It is not able to understand a Zigbee Green Power frame emitted with a switch in harversting energy technology.
Who can recommend the right example to capture this type of signal?
Cordially
fbedon
Postby fbedon » Wed Apr 23, 2025 11:44 am
Hi everyone.
Well, the ESP32-C6 circuit is absolutely not supported by its manufacturer in the Zigbee Green Power aspects, especially with switch in harversting energy technology.
While waiting to have available an example and a development tool at the level of Espressif, I recommend to use for this the dongle NTX OM15080.
Regards
Fred
Users browsing this forum: ChatGPT-User, PetalBot, Qwantbot and 2 guests
