Erratic ping in "Station" mode
offin_wifi
Postby offin_wifi » Thu Mar 06, 2025 10:11 pm
We are using the ESP32-C3 with the AT firmware V3.3.0.0.
In "SoftAP" mode, the ping of the ESP32-C3 is excellent and steady.
In "Station" mode, the ping of the ESP32-C3 is erratic (sometimes < 30 ms and sometimes > 100 ms).
@ other users: could you please tell me about your personal ESP32 ping experience ?
@ Espressif: is it possible to improve the ping in Station mode ?
Thank you in advance for you help.
Re: Erratic ping in "Station" mode
Postby Sprite » Fri Mar 07, 2025 12:16 am
Probably because modem power saving is enabled. I don't know how to disable that in AT mode, though.
esp-at
Postby esp-at » Fri Mar 07, 2025 2:15 am
Please send `AT+SLEEP=0` command to disable sleep mode.
https://docs.espressif.com/projects/esp ... .html#id39
offin_wifi
Postby offin_wifi » Fri Mar 07, 2025 4:05 pm
Thank you very much for your prompt answer.
Before posting in the forum i was already suspicious regarding the "power control" functions and i was investigating about the command "AT+CWPOWER" but i discovered that the ESP32-C3 does not handle it, and i was not able to find the command "AT+SLEEP".
The ping in Station mode is excellent now with "AT+SLEEP=0", same as in SoftAP mode.
Thank you again !
esp-at
Postby esp-at » Tue Mar 18, 2025 3:34 am
no worries
