ESP-32 C3 cannot change range with AP
oneseventhree
Postby oneseventhree » Thu Mar 13, 2025 1:52 am
Hi all,
I have a ESP-32 C3 that works perfectly fine, but I cannot connect to the AP after a fresh installation.
Once I erase and reinstall ESP Presence, the device does not find the Wifi AP for me to connect to to change the properties.
The device works because after I disconnect and reconnect the power, I can flash my own config file to it and it connects to my network.
I can just never see it as an AP to change settings.
Is there another way to change the settings once flashed with my own config?
ahsrabrifat
Re: ESP-32 C3 cannot change range with AP
Postby ahsrabrifat » Thu Mar 13, 2025 6:08 pm
If you can flash a working config, you can modify the settings in the config.json file before flashing. This allows you to set SSID, password, MQTT settings, and other parameters.
Users browsing this forum: Applebot, Qwantbot and 1 guest
