How to relocate or rename main\ & build\ directories
justinmreina
Contact:
Postby justinmreina » Fri Mar 14, 2025 3:01 pm
Hi, I am having troubles finding how to rename the main\ & build\ sub-directories of a new project
Task:
  • Is it possible to rename the build\ directory (e.g. rename it to "out\"?)
  • Is it possible to rename the main\ directory (e.g. rename it to "src\"?)
I have done a lot of research, and nothing has worked! Are there some sdkconfig option perhaps?
Thanks,
Justin
*I am currently developing against the ESP32-S3 using Espressif IDE v3.2.0 and ESP-IDF v5.4 on a Win11 machine
Re: How to relocate or rename main\ & build\ directories
Postby Sprite » Sat Mar 15, 2025 12:35 am
[*] Is it possible to rename the build\ directory (e.g. rename it to "out\"?)
I *think* you can put a 'set(CMAKE_BINARY_DIR "/out")' in your project cmake, but I'm not sure if anyone ever tried to change the build dir, so I have no idea how far that will get you.
[*] Is it possible to rename the main\ directory (e.g. rename it to "src\"?)
Yes.
justinmreina
Contact:
Postby justinmreina » Sat Mar 15, 2025 5:13 pm
Excellent, thank you @ESP_Sprite! I have captured my findings in my reference project now -
Example: Findings:
  1. rename main\ - "set(EXTRA_COMPONENT_DIRS ${CMAKE_CURRENT_LIST_DIR}/newDirName)" (example)
  2. do not rename build\ - this appears a default for the Espressif toolchain
See the readme in above repo for detail
Hide Build Example.png (142.12 KiB) Viewed 309 times
