I am trying to build the ESP32-P4 "esp_brookesia_phone" example, but I am getting errors. I'm using IDF V5.4 and followed the readme instructions. Any ideas would be appreciated. Here's the log file output. The error is near the bottom.
info: INFO: Symbol BSP_I2S_NUM defined in multiple locations (see below). Please check if this is a correct behavior or a random name match:
C:\esp-dev-kits\examples\esp32-p4-function-ev-board\examples\common_components\bsp_extra\Kconfig:2
C:\esp-dev-kits\examples\esp32-p4-function-ev-board\examples\esp_brookesia_phone\managed_components\espressif__esp32_p4_function_ev_board\Kconfig:30
info: INFO: Symbol ESP_SDIO_PIN_D1 defined in multiple locations (see below). Please check if this is a correct behavior or a random name match:
C:\esp-dev-kits\examples\esp32-p4-function-ev-board\examples\esp_brookesia_phone\managed_components\espressif__esp_hosted\Kconfig:487
C:\esp-dev-kits\examples\esp32-p4-function-ev-board\examples\esp_brookesia_phone\managed_components\espressif__esp_hosted\Kconfig:461
ninja: error: mkdir(esp-idf/esp_wifi/CMakeFiles/__idf_esp_wifi.dir/C_/esp-dev-kits/examples/esp32-p4-function-ev-board/examples/esp_brookesia_phone/managed_components/espressif__esp_wifi_remote): No such file or directory
ESP32-P4 Example Build Error
ahsrabrifat
Re: ESP32-P4 Example Build Error
Did you install all the libraries meticulously? The error 'No such file or directory' usually occurs when there is a library missing.
Instead of trying to build the demo project using my Windows 10 PC, I decided to try it on my Mac Mini M1. I was able to build the project without any issues using the exact same steps. I still need to figure out why Windows 10 won't build it for me, as this is my work computer and the Mac is my home computer.
To me it looks like issue with internet connection.
When you build first time or do fullclean some components are downloaded from github in this case.
Users browsing this forum: Bing [Bot], ChatGPT-User, Google [Bot], PerplexityBot, Qwantbot and 0 guests
