ESP32 AT command example for HTTPS API with bearer token and json
Posted: Wed Mar 26, 2025 6:24 am
by Dominykas Litvaitis
I cannot for the life of me figure out, how to send a HTTPS POST with bearer token and json content.
I am able to GET data with HTTPS like this:
AT+CIPSTART="SSL","www.esp32.com",443
AT+CIPSEND=88
GET https://www.esp32.com/index.php HTTP/1.1
Host: www.esp32.com
Connection: close
So the ESP32 works, but I can not figure it out, how to translate this:
POST /abcde/rest/datasetData/dataInfoRecent HTTP/1.1
Host: abcdef.abcde.com
Authorization: bearer aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Content-Type: application/json
Content-Length: 46
    "52256:REMOTE_CATEGORIZED_DATASET"
I tried multiple variations of this:
AT+CIPSTART="SSL","www.abcdef.abcde.com",443
AT+CIPSEND=278
Content-Length: 46
I get OK, so the length is okay, but then after like 5 seconds the connection closes. That means something is wrong in how I formatted the command.
The other thing, is I believe that the POST itself is correct. I was able to get it working in Postman. Then I just took the HTTP code snippet from Postman.
So all in all, the POST is correct and the ESP32 definitely works, that means the problem is I cannot format the request correctly for it to work. Any ideas?
Re: ESP32 AT command example for HTTPS API with bearer token and json
Posted: Wed Mar 26, 2025 11:15 am
by esp-at
could you please use `curl` tool to post a http post request?
If it works, you can append the `--verbose` or `--trace dump.txt` to the curl command, and see more talkative logs.
And then you can make the same http request header on esp32 to the curl.
