Inquiry on Thermal Resistance Values for ESP32-D0WD
Ad3ohm
Postby Ad3ohm » Thu Mar 27, 2025 10:29 pm
I am working on a project using the ESP32 UWB Pro (WROVER) module, which is based on the ESP32-D0WD chip. As part of our thermal management design, I need to determine the junction-to-ambient (θJA) and junction-to-case (θJC) thermal resistance values for the ESP32-D0WD.
I have reviewed the available datasheets for both the ESP32-WROVER module and the ESP32-D0WD chip but have not found these specific values. Could you provide the thermal resistance specifications or any guidance on estimating heat dissipation in an embedded application?
Thank you for your time and assistance. I appreciate any information you can share.
ahsrabrifat
Re: Inquiry on Thermal Resistance Values for ESP32-D0WD
Postby ahsrabrifat » Fri Mar 28, 2025 8:25 am
Monitor the module's temperature under typical operating conditions using thermocouples or infrared thermometers.
