Secure boot and flash encrytion in developmentmode using host generated key and ota issue
Posted: Fri Apr 11, 2025 6:51 am
by jerryc
esp 32e wroom
idf 5.4.0
Windows
VS Code
the flash steps :
`espsecure.py generate_flash_encryption_key key.bin
Enable flash encryption on boot (READ DOCS FIRST)
Enable usage mode - development
Enable hardware Secure Boot in bootloader
boot version
Select secure boot version - 1
Secure bootloader mode - refreshable
Offset of partition table - 0xd000
Partition Table - custom partition table csv
Name ,Type,SubType,Offset,Size,Flags
nvs, data, nvs, 0xE000, 0x4000,
otadata, data, ota, 0x12000, 0x2000,
phy_int, data, phy, 0x14000, 0x1000,
ota_0, app, ota_0, 0x20000, 0x1A0000,
ota_1, app, ota_1, 0x1C0000,0x1A0000
disable NVS encryption
espsecure.py generate_signing_key secure_boot_signing_key.pem --version 1 --scheme ecdsa256
build
espsecure.py encrypt_flash_data --keyfile key.bin --address 0x1000 -o key_bootloader.bin build/bootloader/bootloader.bin
espsecure.py encrypt_flash_data --keyfile key.bin --address 0xd000 -o key_partition-table.bin build/partition_table/partition-table.bin
espsecure.py encrypt_flash_data --keyfile key.bin --address 0x20000 -o key_myapp.bin build/myapp.bin
espefuse.py --port COM10 burn_key flash_encryption key.bin
espefuse.py --port COM10 burn_efuse FLASH_CRYPT_CONFIG 0xF FLASH_CRYPT_CNT 1
esptool.py -b 460800 --before default_reset --after no_reset --chip esp32 write_flash --flash_mode dio --flash_size detect --flash_freq 40m 0x1000 key_bootloader.bin 0xd000 key_partition-table.bin 0x20000 key_myapp.bin`
aftet doing these, it works on esp32.
But when i try to use the code in simple_ota_example to ota the key_myapp.bin, error shows ’Mismatch chip id, expected 0, found 16916‘. (ota works when i didn't enable flash encryption and boot security)
I try to use 'espsecure.py encrypt_flash_data --keyfile key.bin --address 0x1C0000 -o key_myapp.bin build/myapp.bin', also fails.
So can i ota an encrypted bin using host generated key? How can i do? Thanks for your help!
