PYTHON CODE (Flask server for face recognition):
from flask import Flask, request, jsonify
import face_recognition
import cv2
import numpy as np
import os
app = Flask(__name__)
REFERENCE_IMAGES_DIR = r"C:\project\refrence images"
known_encodings = []
known_names = []
def load_reference_images():
global known_encodings, known_names
for file_name in os.listdir(REFERENCE_IMAGES_DIR):
if file_name.lower().endswith(('.png', '.jpg', '.jpeg')):
name = os.path.splitext(file_name)[0]
file_path = os.path.join(REFERENCE_IMAGES_DIR, file_name)
try:
image = face_recognition.load_image_file(file_path)
encodings = face_recognition.face_encodings(image)
if encodings:
known_encodings.append(encodings[0])
known_names.append(name)
print(f"Loaded reference image: {file_name} -> {name}")
else:
print(f"No face detected in reference image: {file_name}")
except Exception as e:
print(f"Error loading reference image {file_name}: {e}")
@app.route('/upload', methods=['POST'])
def upload():
if 'image' not in request.files:
return jsonify({"message": "No image data received", "access": "denied"}), 400
file = request.files['image']
if file.filename == '':
return jsonify({"message": "No selected file", "access": "denied"}), 400
upload_path = "received_image.jpg"
file.save(upload_path)
try:
image = face_recognition.load_image_file(upload_path)
face_locations = face_recognition.face_locations(image)
face_encodings = face_recognition.face_encodings(image, face_locations)
if not face_encodings:
return jsonify({"message": "No face detected", "access": "denied"}), 200
for face_encoding in face_encodings:
matches = face_recognition.compare_faces(known_encodings, face_encoding, tolerance=0.5)
face_distances = face_recognition.face_distance(known_encodings, face_encoding)
best_match_index = np.argmin(face_distances) if face_distances.size > 0 else -1
if best_match_index != -1 and matches[best_match_index]:
name = known_names[best_match_index]
return jsonify({"message": f"Welcome {name}<3", "access": "granted"}), 200
return jsonify({"message": "Unknown Face", "access": "denied"}), 200
return jsonify({"message": f"Error processing image: {str(e)}", "access": "denied"}), 500
finally:
if os.path.exists(upload_path):
os.remove(upload_path)
if __name__ == '__main__':
app.run(host='0.0.0.0', port=5000, debug=True)
#include <WiFi.h>
#include <HTTPClient.h>
#include "esp_camera.h"
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
// WiFi and Server Settings
#define SSID "wifiaddress"
#define PASSWORD "12345678910"
#define SERVER_URL "http://192.168.1.34:5000/upload"
// Camera Pin Definitions
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
// OLED Display Settings
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define SDA_PIN 15
#define SCL_PIN 13
// Hardware Pins
#define BUZZER_PIN 2 // Buzzer
#define BUTTON_PIN 12 // Push button (doorbell)
#define IR_SENSOR_PIN 16 // IR motion sensor
#define LOCK_PIN 4 // Relay control pin for solenoid lock
Adafruit_SH1106G display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
void setupCamera() {
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
config.frame_size = FRAMESIZE_QQVGA; // Smaller resolution (160x120)
config.jpeg_quality = 12; // Higher quality
config.fb_count = 1;
if (esp_camera_init(&config) != ESP_OK) {
Serial.println("Camera init failed! Restarting...");
delay(5000);
ESP.restart();
Serial.println("Camera initialized successfully");
void connectWiFi() {
WiFi.begin(SSID, PASSWORD);
Serial.print("Connecting to WiFi...");
unsigned long wifiStartTime = millis();
delay(500);
Serial.print(".");
if (millis() - wifiStartTime > 15000) { // Timeout after 15 seconds
Serial.println("\nWiFi connection failed. Restarting...");
ESP.restart();
Serial.println("\nConnected to WiFi!");
bool sendImageAndGetResponse() {
camera_fb_t *fb = esp_camera_fb_get();
if (!fb || fb->len == 0 || !fb->buf) {
Serial.println("Camera capture failed!");
if (fb) esp_camera_fb_return(fb);
return false;
Serial.printf("Captured image size: %d bytes\n", fb->len);
String boundary = "----ESP32Boundary";
String bodyStart = "--" + boundary + "\r\n";
bodyStart += "Content-Disposition: form-data; name=\"image\"; filename=\"image.jpg\"\r\n";
bodyStart += "Content-Type: image/jpeg\r\n\r\n";
String bodyEnd = "\r\n--" + boundary + "--\r\n";
size_t payloadSize = bodyStart.length() + fb->len + bodyEnd.length();
uint8_t *payload = (uint8_t *)malloc(payloadSize);
if (!payload) {
Serial.println("Failed to allocate memory for payload. Restarting...");
delay(1000);
ESP.restart();
memcpy(payload, bodyStart.c_str(), bodyStart.length());
memcpy(payload + bodyStart.length(), fb->buf, fb->len);
memcpy(payload + bodyStart.length() + fb->len, bodyEnd.c_str(), bodyEnd.length());
HTTPClient http;
bool accessGranted = false;
http.begin(SERVER_URL);
http.addHeader("Content-Type", "multipart/form-data; boundary=" + boundary);
http.addHeader("Content-Length", String(payloadSize));
int httpResponseCode = http.POST(payload, payloadSize);
if (httpResponseCode == 200) {
String response = http.getString();
Serial.printf("HTTP Response: %s\n", response.c_str());
if (response.indexOf("\"access\": \"granted\"") != -1) {
accessGranted = true;
Serial.printf("Error: HTTP Response Code %d\n", httpResponseCode);
accessGranted = false; // Default to denied in case of error
http.end(); // Close the HTTP connection
free(payload); // Free the allocated memory
esp_camera_fb_return(fb); // Release the frame buffer
return accessGranted;
Wire.begin(SDA_PIN, SCL_PIN);
// Initialize OLED Display
if (!display.begin(0x3C, true)) {
Serial.println(F("SH1106 allocation failed"));
for (;;); // Stop execution if the display fails
display.clearDisplay();
display.setTextSize(2);
display.setTextColor(SH110X_WHITE);
resetOLED();
pinMode(BUZZER_PIN, OUTPUT);
pinMode(BUTTON_PIN, INPUT_PULLUP);
pinMode(IR_SENSOR_PIN, INPUT);
pinMode(LOCK_PIN, OUTPUT);
digitalWrite(BUZZER_PIN, LOW);
digitalWrite(LOCK_PIN, LOW);
setupCamera();
connectWiFi();
Serial.println("System Initialized.");
int buttonState = digitalRead(BUTTON_PIN);
int motionDetected = digitalRead(IR_SENSOR_PIN);
Serial.print("Button state: ");
Serial.println(buttonState == LOW ? "Pressed" : "Not Pressed");
Serial.print("Motion detected: ");
Serial.println(motionDetected == LOW ? "Yes" : "No");
if (buttonState == LOW) {
Serial.println("Doorbell Pressed!");
showMessage("Doorbell Ringing");
delay(1000);
tone(BUZZER_PIN, 1000);
delay(500);
noTone(BUZZER_PIN);
delay(1000);
resetOLED();
if (motionDetected == LOW || buttonState == LOW) {
Serial.println("Trigger detected: Capturing image...");
showMessage("Capturing Face...");
delay(1000);
// Send image and get server response
bool accessGranted = sendImageAndGetResponse();
if (accessGranted) {
Serial.println("Face recognized: Access Granted.");
showMessage("Access\nGranted\nWelcome!");
digitalWrite(LOCK_PIN, HIGH); // Unlock door
delay(5000); // Keep unlocked for 5 seconds
digitalWrite(LOCK_PIN, LOW); // Lock door again
Serial.println("Unlock the door");
Serial.println("Unknown Face: Access Denied.");
Serial.println("Lock the door");
showMessage("Access \nDenied!\nAlert!");
delay(1000);
for (int i = 0; i < 3; i++) {
tone(BUZZER_PIN, 800);
delay(150);
tone(BUZZER_PIN, 1200);
delay(150);
noTone(BUZZER_PIN);
delay(1500);
resetOLED();
delay(500);
void showMessage(const char *message) {
display.setCursor(0, 10);
display.print(message);
display.display();
void resetOLED() {
showMessage("Welcome!\nSystem is Ready");
delay(2000);
Connected to WiFi!
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x40094c91 PS : 0x00060430 A0 : 0x800946bc A1 : 0x3ffb1fc0
A2 : 0xffffffff A3 : 0x000002f4 A4 : 0x3ffb20b4 A5 : 0x00060423
A6 : 0x3ffc7eb0 A7 : 0x00000000 A8 : 0x000002f4 A9 : 0xfffffffc
A10 : 0x00000003 A11 : 0xffffffff A12 : 0x00060420 A13 : 0x3f419ba0
A14 : 0xffffffff A15 : 0x00000000 SAR : 0x0000001a EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000000f LBEG : 0x4008b9a0 LEND : 0x4008b9ab LCOUNT : 0x00000000
``However, the issue arises when integrating them — that is, when the ESP32-CAM attempts to send the image to the Flask server and process the server's response to trigger the circuit. This part is not functioning correctly, even though both components are verified to work flawlessly on their own. Any help would be appreciated thank you
