NO‑EOI errors, OV2604, ESP32-CAM module (AiThinker), JPEG, UXGA, quality 0
fiba2331
Postby fiba2331 » Sun Apr 13, 2025 8:05 pm
Hi everyone,
I’m experiencing an issue with my ESP32‑CAM (AiThinker) module equipped with the OV2640 sensor. My current goal is to capture images in JPEG mode at UXGA resolution (1600×1200) with maximum quality (jpeg_quality = 0). However, when I set jpeg_quality to 0, I frequently encounter errors in JPEG compression - the sensor fails to form a complete JPEG image. The serial logs show repeated “NO-EOI” warnings (indicating that the End-Of-Image marker isn’t present) and eventually a failure to capture the frame.
In contrast, when I use RAW mode (e.g., RGB565) or set JPEG quality to 5 or more, the capture works as expected.
Additional details:
  • In RAW mode (e.g., using PIXFORMAT_RGB565), the module captures images correctly – for UXGA (1600×1200), the frame buffer size is approximately 3,840,000 bytes (calculated as 1600 × 1200 × 2).
  • In JPEG mode with lower quality settings (e.g., jpeg_quality = 5), the module works stably.
  • However, when using maximum quality (jpeg_quality = 0), the OV2640 fails to complete JPEG compression – it does not produce the proper end marker (NO-EOI error), and the frame capture fails.
  • I have already adjusted buffer allocation to ensure around 3.95 MB is available, so memory allocation does not seem to be the limiting factor.
  • My future goal is to transmit these high-quality JPEG images via an HTTP server so that they can be viewed directly in a browser, and then process these images using Google Vision to extract text that will be forwarded to ChatGPT for further analysis. However, currently - even before HTTP integration - capturing a full JPEG image at maximum quality proves problematic.
Questions:
  • Has anyone experienced issues with the OV2640 failing to complete JPEG compression (NO-EOI errors) at maximum quality (jpeg_quality = 0) in UXGA mode?
  • Is this likely an inherent limitation of the OV2640’s built-in JPEG encoder when operating at such high resolution and minimal compression?
  • Are there any recommended adjustments (for example, tweaking the XCLK frequency or other timing parameters) that might allow stable JPEG capture at maximum quality?
  • If these issues persist due to sensor limitations, would upgrading to a more powerful sensor (e.g., one with a better hardware JPEG encoder, like the OV5640) resolve the problem and support future HTTP transmission reliably?
Any insights, suggestions, or experiences would be greatly appreciated. Thanks in advance!
My current project structure: (it is just very easy project)
  • managed_components Folder:
    This folder contains the entire official repository code for the esp32-camera component from Espressif.
    (I can provide more details if needed, though I believe it is the standard content from the official repository.)
  • main Folder:
    This folder contains my application code including:
    • take_picture.c
    • idf_component.yml
    • CMakeLists.txt
take_picture.c:
* This example takes a picture every 5 seconds and prints its size on the serial monitor.
#include "sdkconfig.h"
#define CONFIG_ESP_WIFI_STATIC_RX_BUFFER_NUM 10
#include <esp_log.h>
#include <esp_system.h>
#include <nvs_flash.h>
#include <sys/param.h>
#include <string.h>
#include "freertos/task.h"
#include "esp_camera.h"
#define portTICK_RATE_MS portTICK_PERIOD_MS
#define CAM_PIN_PWDN   32
#define CAM_PIN_RESET  -1
#define CAM_PIN_XCLK   0
#define CAM_PIN_SIOD   26
#define CAM_PIN_SIOC   27
#define CAM_PIN_D7     35
#define CAM_PIN_D6     34
#define CAM_PIN_D5     39
#define CAM_PIN_D4     36
#define CAM_PIN_D3     21
#define CAM_PIN_D2     19
#define CAM_PIN_D1     18
#define CAM_PIN_D0     5
#define CAM_PIN_VSYNC  25
#define CAM_PIN_HREF   23
#define CAM_PIN_PCLK   22
static const char *TAG = "example:take_picture";
#if ESP_CAMERA_SUPPORTED
static camera_config_t camera_config = {
    .pin_pwdn       = CAM_PIN_PWDN,
    .pin_reset      = CAM_PIN_RESET,
    .pin_xclk       = CAM_PIN_XCLK,
    .pin_sccb_sda   = CAM_PIN_SIOD,
    .pin_sccb_scl   = CAM_PIN_SIOC,
    .pin_d7         = CAM_PIN_D7,
    .pin_d6         = CAM_PIN_D6,
    .pin_d5         = CAM_PIN_D5,
    .pin_d4         = CAM_PIN_D4,
    .pin_d3         = CAM_PIN_D3,
    .pin_d2         = CAM_PIN_D2,
    .pin_d1         = CAM_PIN_D1,
    .pin_d0         = CAM_PIN_D0,
    .pin_vsync      = CAM_PIN_VSYNC,
    .pin_href       = CAM_PIN_HREF,
    .pin_pclk       = CAM_PIN_PCLK,
    .xclk_freq_hz   = 10000000, // also tried to use 20000000
    .ledc_timer     = LEDC_TIMER_0,
    .ledc_channel   = LEDC_CHANNEL_0,
    .pixel_format   = PIXFORMAT_JPEG,   //in PIXFORMAT_RGB565 works properly
    .frame_size     = FRAMESIZE_UXGA,
    .jpeg_quality   = 0,    // in this state it is not working(NO-EOI), but when it is 5 it works properly
                            // when it is 4 it sometimes has problems, but still working
    .fb_count       = 1,
    .fb_location    = CAMERA_FB_IN_PSRAM,
    .grab_mode      = CAMERA_GRAB_WHEN_EMPTY,
static esp_err_t init_camera(void)
    esp_err_t err = esp_camera_init(&camera_config);
    if(err != ESP_OK) {
        ESP_LOGE(TAG, "Camera Init Failed with error 0x%x", err);
        return err;
    return ESP_OK;
#endif
void app_main(void)
    if(ESP_OK != init_camera()){
        return;
    while(1) {
        ESP_LOGI(TAG, "Taking picture...");
        camera_fb_t *pic = esp_camera_fb_get();
        if(pic) {
            ESP_LOGI(TAG, "Picture taken! Its size was: %zu bytes", pic->len);
            esp_camera_fb_return(pic);
            ESP_LOGE(TAG, "Camera capture failed");
        vTaskDelay(5000 / portTICK_RATE_MS);
#else
    ESP_LOGE(TAG, "Camera support is not available for this chip");
    return;
#endif
idf_component.yml:
dependencies:
  espressif/esp32-camera:
    version: '*'
CMakeLists.txt:
idf_component_register(SRCS take_picture.c
                        PRIV_INCLUDE_DIRS .
                        PRIV_REQUIRES nvs_flash esp_psram esp_http_server esp_wifi esp_timer)
rtruninger
Re: NO‑EOI errors, OV2604, ESP32-CAM module (AiThinker), JPEG, UXGA, quality 0
Postby rtruninger » Thu May 08, 2025 6:54 am
Hi
I've got exactly the same issue, what I have found is that when the resulting compressed JPEG image is about 250kB or more I get the EOI errors, which happens at UXGA when JPEG compression is 4 or lower.I have not tried RAW yet, but this encourages me to implement raw mode and then do PNG compression. Have you found a solution to the issue yet?
I'm using a wroom ESP32-S3 with 8MB PSRAM/16MBFlash and OV2640.
Jonathan2892
Postby Jonathan2892 » Mon Jan 19, 2026 11:09 am
Hey,
did you find a solution for your problem?
Best
Jonathan
Users browsing this forum: PerplexityBot and 8 guests
