Problems with i80 16 bits LVGL animations
Posted: Mon Apr 14, 2025 9:41 am
I don’t understand why, when I use the 8080 16-bit configuration, the LVGL animations show tearing, while using 8080 8-bit with the same display works perfectly.
I’m using the ST7789VI controller and ESP32-S3 module.
Static images look fine in both 8-bit and 16-bit modes.
This is how I have it configured:
// i80_bus.c
#include "esp_timer.h"
#include "esp_err.h"
#include "esp_log.h"
#include "esp_lcd_panel_io.h"
#include "esp_lcd_panel_vendor.h"
#include "esp_lcd_panel_ops.h"
#include "driver/gpio.h"
#include "i80_bus.h"
#include "i80_config.h"
#include "freertos/task.h"
#include "freertos/semphr.h"
#define EXAMPLE_LCD_PIXEL_CLOCK_HZ (10 * 1000 * 1000)
#define EXAMPLE_LCD_BK_LIGHT_ON_LEVEL 1
#define EXAMPLE_LCD_BK_LIGHT_OFF_LEVEL !EXAMPLE_LCD_BK_LIGHT_ON_LEVEL
#if CONFIG_LCD_I80_BUS_WIDTH_8
#define EXAMPLE_LCD_I80_BUS_WIDTH 8
#define EXAMPLE_PIN_NUM_DATA0 48
#define EXAMPLE_PIN_NUM_DATA1 45
#define EXAMPLE_PIN_NUM_DATA2 39
#define EXAMPLE_PIN_NUM_DATA3 38
#define EXAMPLE_PIN_NUM_DATA4 41
#define EXAMPLE_PIN_NUM_DATA5 40
#define EXAMPLE_PIN_NUM_DATA6 2
#define EXAMPLE_PIN_NUM_DATA7 42
#define EXAMPLE_PIN_NUM_PCLK 3
#define EXAMPLE_PIN_NUM_CS 17
#define EXAMPLE_PIN_NUM_DC 46
#define EXAMPLE_PIN_NUM_RST 1
#define EXAMPLE_PIN_NUM_BK_LIGHT -1
#define PIN_NUM_RD -1
#define PIN_IM0 -1
#define PIN_IM2 -1
#elif CONFIG_LCD_I80_BUS_WIDTH_16
#define EXAMPLE_LCD_I80_BUS_WIDTH 16
#define EXAMPLE_PIN_NUM_DATA0 9
#define EXAMPLE_PIN_NUM_DATA1 10
#define EXAMPLE_PIN_NUM_DATA2 11
#define EXAMPLE_PIN_NUM_DATA3 12
#define EXAMPLE_PIN_NUM_DATA4 13
#define EXAMPLE_PIN_NUM_DATA5 14
#define EXAMPLE_PIN_NUM_DATA6 21
#define EXAMPLE_PIN_NUM_DATA7 47
#define EXAMPLE_PIN_NUM_DATA8 48
#define EXAMPLE_PIN_NUM_DATA9 45
#define EXAMPLE_PIN_NUM_DATA10 39
#define EXAMPLE_PIN_NUM_DATA11 38
#define EXAMPLE_PIN_NUM_DATA12 41
#define EXAMPLE_PIN_NUM_DATA13 40
#define EXAMPLE_PIN_NUM_DATA14 2
#define EXAMPLE_PIN_NUM_DATA15 42
#define EXAMPLE_PIN_NUM_BK_LIGHT 4
#define PIN_IM0 -1
#define PIN_IM2 -1
#endif
// The pixel number in horizontal and vertical
#define EXAMPLE_LCD_H_RES 320
#define EXAMPLE_LCD_V_RES 240
// Bit number used to represent command and parameter
#define EXAMPLE_LCD_CMD_BITS 8
#define EXAMPLE_LCD_PARAM_BITS 8
#define EXAMPLE_LVGL_TICK_PERIOD_MS 2
#define EXAMPLE_LVGL_TASK_MAX_DELAY_MS 500
#define EXAMPLE_LVGL_TASK_MIN_DELAY_MS 1
#define EXAMPLE_LVGL_TASK_STACK_SIZE (4 * 1024)
#define EXAMPLE_LVGL_TASK_PRIORITY 2
#define EXAMPLE_DMA_BURST_SIZE 64 // 16, 32, 64. Higher burst size can improve the performance when the DMA buffer comes from PSRAM
static const char *TAG = "i80_bus";
static SemaphoreHandle_t lvgl_mux = NULL;
static bool example_notify_lvgl_flush_ready(esp_lcd_panel_io_handle_t panel_io, esp_lcd_panel_io_event_data_t *edata, void *user_ctx)
lv_disp_drv_t *disp_driver = (lv_disp_drv_t *)user_ctx;
lv_disp_flush_ready(disp_driver);
return false;
static void example_lvgl_flush_cb(lv_disp_drv_t *drv, const lv_area_t *area, lv_color_t *color_map)
esp_lcd_panel_handle_t panel_handle = (esp_lcd_panel_handle_t) drv->user_data;
int offsetx1 = area->x1;
int offsetx2 = area->x2;
int offsety1 = area->y1;
int offsety2 = area->y2;
// copy a buffer's content to a specific area of the display
esp_lcd_panel_draw_bitmap(panel_handle, offsetx1, offsety1, offsetx2 + 1, offsety2 + 1, color_map);
bool lvgl_lock(int timeout_ms)
// Convert timeout in milliseconds to FreeRTOS ticks
// If `timeout_ms` is set to -1, the program will block until the condition is met
const TickType_t timeout_ticks = (timeout_ms == -1) ? portMAX_DELAY : pdMS_TO_TICKS(timeout_ms);
return xSemaphoreTakeRecursive(lvgl_mux, timeout_ticks) == pdTRUE;
void lvgl_unlock(void)
xSemaphoreGiveRecursive(lvgl_mux);
static void example_lvgl_port_task(void *arg)
ESP_LOGI(TAG, "Starting LVGL task");
uint32_t task_delay_ms = EXAMPLE_LVGL_TASK_MAX_DELAY_MS;
while (1) {
// Lock the mutex due to the LVGL APIs are not thread-safe
if (lvgl_lock(-1)) {
task_delay_ms = lv_timer_handler();
// Release the mutex
lvgl_unlock();
if (task_delay_ms > EXAMPLE_LVGL_TASK_MAX_DELAY_MS) {
} else if (task_delay_ms < EXAMPLE_LVGL_TASK_MIN_DELAY_MS) {
task_delay_ms = EXAMPLE_LVGL_TASK_MIN_DELAY_MS;
vTaskDelay(pdMS_TO_TICKS(task_delay_ms));
static void example_increase_lvgl_tick(void *arg)
/* Tell LVGL how many milliseconds has elapsed */
lv_tick_inc(EXAMPLE_LVGL_TICK_PERIOD_MS);
void example_init_i80_bus(esp_lcd_panel_io_handle_t *io_handle, void *user_ctx)
ESP_LOGI(TAG, "Initialize Intel 8080 bus");
esp_lcd_i80_bus_handle_t i80_bus = NULL;
esp_lcd_i80_bus_config_t bus_config = {
.clk_src = LCD_CLK_SRC_DEFAULT,
.dc_gpio_num = EXAMPLE_PIN_NUM_DC,
.wr_gpio_num = EXAMPLE_PIN_NUM_PCLK,
.data_gpio_nums = {
EXAMPLE_PIN_NUM_DATA0, EXAMPLE_PIN_NUM_DATA1, EXAMPLE_PIN_NUM_DATA2,
EXAMPLE_PIN_NUM_DATA3, EXAMPLE_PIN_NUM_DATA4, EXAMPLE_PIN_NUM_DATA5,
EXAMPLE_PIN_NUM_DATA6, EXAMPLE_PIN_NUM_DATA7,
#if CONFIG_LCD_I80_BUS_WIDTH_16
EXAMPLE_PIN_NUM_DATA8, EXAMPLE_PIN_NUM_DATA9, EXAMPLE_PIN_NUM_DATA10,
EXAMPLE_PIN_NUM_DATA11, EXAMPLE_PIN_NUM_DATA12, EXAMPLE_PIN_NUM_DATA13,
EXAMPLE_PIN_NUM_DATA14, EXAMPLE_PIN_NUM_DATA15,
#endif
.bus_width = EXAMPLE_LCD_I80_BUS_WIDTH,
.max_transfer_bytes = EXAMPLE_LCD_H_RES * 100 * sizeof(uint16_t),
.dma_burst_size = EXAMPLE_DMA_BURST_SIZE,
ESP_ERROR_CHECK(esp_lcd_new_i80_bus(&bus_config, &i80_bus));
esp_lcd_panel_io_i80_config_t io_config = {
.cs_gpio_num = EXAMPLE_PIN_NUM_CS,
.pclk_hz = EXAMPLE_LCD_PIXEL_CLOCK_HZ,
.trans_queue_depth = 10,
.dc_levels = {
.dc_idle_level = 0,
.dc_cmd_level = 0,
.dc_dummy_level = 0,
.dc_data_level = 1,
.flags = {
.swap_color_bytes = !LV_COLOR_16_SWAP, // Swap can be done in LvGL (default) or DMA
.on_color_trans_done = example_notify_lvgl_flush_ready,
.user_ctx = user_ctx,
.lcd_cmd_bits = EXAMPLE_LCD_CMD_BITS,
.lcd_param_bits = EXAMPLE_LCD_PARAM_BITS,
ESP_ERROR_CHECK(esp_lcd_new_panel_io_i80(i80_bus, &io_config, io_handle));
void example_init_lcd_panel(esp_lcd_panel_io_handle_t io_handle, esp_lcd_panel_handle_t *panel)
esp_lcd_panel_handle_t panel_handle = NULL;
#if CONFIG_EXAMPLE_LCD_I80_CONTROLLER_ST7789
ESP_LOGI(TAG, "Install LCD driver of st7789");
esp_lcd_panel_dev_config_t panel_config = {
.reset_gpio_num = EXAMPLE_PIN_NUM_RST,
.rgb_ele_order = LCD_RGB_ELEMENT_ORDER_RGB,
.bits_per_pixel = 16,
ESP_ERROR_CHECK(esp_lcd_new_panel_st7789(io_handle, &panel_config, &panel_handle));
esp_lcd_panel_reset(panel_handle);
esp_lcd_panel_init(panel_handle);
// Set inversion, x/y coordinate order, x/y mirror according to your LCD module spec
// the gap is LCD panel specific, even panels with the same driver IC, can have different gap value
esp_lcd_panel_swap_xy(panel_handle, true);
esp_lcd_panel_mirror(panel_handle, true, false);
esp_lcd_panel_invert_color(panel_handle, true);
esp_lcd_panel_set_gap(panel_handle, 0, 0);
#elif CONFIG_EXAMPLE_LCD_I80_CONTROLLER_NT35510
ESP_LOGI(TAG, "Install LCD driver of nt35510");
.rgb_ele_order = LCD_RGB_ELEMENT_ORDER_BGR,
ESP_ERROR_CHECK(esp_lcd_new_panel_nt35510(io_handle, &panel_config, &panel_handle));
#endif
*panel = panel_handle;
lv_disp_t * Start_Display()
static lv_disp_draw_buf_t disp_buf; // contains internal graphic buffer(s) called draw buffer(s)
static lv_disp_drv_t disp_drv; // contains callback functions
/* -------------------- START PINS -------------------- */
#if EXAMPLE_PIN_NUM_BK_LIGHT >= 0
ESP_LOGI(TAG, "Turn off LCD backlight");
gpio_config_t bk_gpio_config = {
.mode = GPIO_MODE_OUTPUT,
.pin_bit_mask = 1ULL << EXAMPLE_PIN_NUM_BK_LIGHT
ESP_ERROR_CHECK(gpio_config(&bk_gpio_config));
gpio_set_level(EXAMPLE_PIN_NUM_BK_LIGHT, EXAMPLE_LCD_BK_LIGHT_OFF_LEVEL);
#endif // EXAMPLE_PIN_NUM_BK_LIGHT >= 0
// gpio_config_t rd_config = {
// .mode = GPIO_MODE_OUTPUT,
// .pin_bit_mask = 1ULL << PIN_NUM_RD
// ESP_ERROR_CHECK(gpio_config(&rd_config));
// gpio_set_level(PIN_NUM_RD, 1);
// gpio_config_t im0_config = {
// .pin_bit_mask = 1ULL << PIN_IM0
// ESP_ERROR_CHECK(gpio_config(&im0_config));
// gpio_set_level(PIN_IM0, 1);
// gpio_config_t im2_config = {
// .pin_bit_mask = 1ULL << PIN_IM2
// ESP_ERROR_CHECK(gpio_config(&im2_config));
// gpio_set_level(PIN_IM2, 0);
/* -------------------- START i80 BUS -------------------- */
esp_lcd_panel_io_handle_t io_handle = NULL;
example_init_i80_bus(&io_handle, &disp_drv); /* Structs already pointers */
example_init_lcd_panel(io_handle, &panel_handle);
// Stub: user can flush pre-defined pattern to the screen before we turn on the screen or backlight
ESP_ERROR_CHECK(esp_lcd_panel_disp_on_off(panel_handle, true));
/* -------------------- BACKLIGHT ON -------------------- */
ESP_LOGI(TAG, "Turn on LCD backlight");
gpio_set_level(EXAMPLE_PIN_NUM_BK_LIGHT, EXAMPLE_LCD_BK_LIGHT_ON_LEVEL);
/* -------------------- START LVGL -------------------- */
ESP_LOGI(TAG, "Initialize LVGL library");
lv_init();
// alloc draw buffers used by LVGL
// it's recommended to choose the size of the draw buffer(s) to be at least 1/10 screen sized
uint32_t draw_buf_alloc_caps = 0;
#if CONFIG_EXAMPLE_LCD_I80_COLOR_IN_PSRAM
draw_buf_alloc_caps |= MALLOC_CAP_SPIRAM;
#endif
lv_color_t *buf1 = esp_lcd_i80_alloc_draw_buffer(io_handle, EXAMPLE_LCD_H_RES * 100 * sizeof(lv_color_t), draw_buf_alloc_caps);
lv_color_t *buf2 = esp_lcd_i80_alloc_draw_buffer(io_handle, EXAMPLE_LCD_H_RES * 100 * sizeof(lv_color_t), draw_buf_alloc_caps);
assert(buf1);
assert(buf2);
ESP_LOGI(TAG, "buf1@%p, buf2@%p", buf1, buf2);
// initialize LVGL draw buffers
lv_disp_draw_buf_init(&disp_buf, buf1, buf2, EXAMPLE_LCD_H_RES * 100);
ESP_LOGI(TAG, "Register display driver to LVGL");
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = EXAMPLE_LCD_H_RES;
disp_drv.ver_res = EXAMPLE_LCD_V_RES;
disp_drv.flush_cb = example_lvgl_flush_cb;
disp_drv.draw_buf = &disp_buf;
disp_drv.user_data = panel_handle;
lv_disp_t *disp = lv_disp_drv_register(&disp_drv);
ESP_LOGI(TAG, "Install LVGL tick timer");
// Tick interface for LVGL (using esp_timer to generate 2ms periodic event)
const esp_timer_create_args_t lvgl_tick_timer_args = {
.callback = &example_increase_lvgl_tick,
.name = "lvgl_tick"
esp_timer_handle_t lvgl_tick_timer = NULL;
ESP_ERROR_CHECK(esp_timer_create(&lvgl_tick_timer_args, &lvgl_tick_timer));
ESP_ERROR_CHECK(esp_timer_start_periodic(lvgl_tick_timer, EXAMPLE_LVGL_TICK_PERIOD_MS * 1000));
lvgl_mux = xSemaphoreCreateRecursiveMutex();
assert(lvgl_mux);
ESP_LOGI(TAG, "Create LVGL task");
xTaskCreate(example_lvgl_port_task, "LVGL", EXAMPLE_LVGL_TASK_STACK_SIZE, NULL, EXAMPLE_LVGL_TASK_PRIORITY, NULL);
return disp;
