ADC: Reading above Vref on an ESP32-S2 with ATTEN_12
Posted: Fri Apr 25, 2025 5:54 pm
I'm having some trouble reading above Vref on an ESP32-S2 in continuous mode. I should be able to read above Vref with ATTEN_12, right?
I'm using a line fitting calibration scheme that's initialized like:
and I'm initializing the continuous handle/config like:
In the interrupt handler, I'm reading the results like:
I'm currently passing in 3v3, so the raw value of 4096 is correct. But when I call `adc_cali_raw_to_voltage`, I would expect voltage to be 2500 mV with DB11/DB12 atten, but it returns 1280 mV.
Do I need to use `adc_cali_scheme_line_fitting_check_efuse` here? Or am I misconfiguring or misunderstanding something here?
adc_cali_line_fitting_config_t cali_config = {
.unit_id = ADC_UNIT_1,
.atten = ADC_ATTEN_DB_12,
.bitwidth = ADC_BITWIDTH_12,
ret = adc_cali_create_scheme_line_fitting(&cali_config, out_handle); // returns ESP_OK
adc_continuous_handle_cfg_t adc_config = {
.max_store_buf_size = 1024, // in bytes
.conv_frame_size = 256 * SOC_ADC_DIGI_DATA_BYTES_PER_CONV, // in bytes
ESP_RETURN_ON_ERROR(
adc_continuous_new_handle(&adc_config, &s_adc_cont_handle), TAG,
"adc_continuous_new_handle failed");
adc_continuous_config_t cont_config = {
.pattern_num = 1,
.adc_pattern =
(adc_digi_pattern_config_t[1]){
(adc_digi_pattern_config_t){
.unit = ADC_UNIT_1,
.channel = ADC_CHANNEL_0,
.bit_width = ADC_BITWIDTH_12,
.sample_freq_hz = 1000,
.conv_mode = ADC_CONV_SINGLE_UNIT_1,
.format = ADC_DIGI_OUTPUT_FORMAT_TYPE1,
ESP_RETURN_ON_ERROR(adc_continuous_config(s_adc_cont_handle, &cont_config),
TAG, "failed to cont config");
esp_err_t err =
adc_continuous_read(s_adc_cont_handle, res, size, &size, 1);
for (int i = 0; i < size; i += SOC_ADC_DIGI_RESULT_BYTES) {
adc_digi_output_data_t *data = (adc_digi_output_data_t *)&res[i];
// int raw_value = data->type2.data;
int raw_value = data->type1.data;
// ESP_LOGI(TAG, "raw = %d", raw_value);
if (adc_cali_raw_to_voltage(s_adc_cali_handle, raw_value, &voltage) ==
ESP_OK) {
// HERE, raw_value was like 4096, but voltage is reading 1280 mV... why?
