/* This is the global interrupt handler for ULP RISC-V.
* It is called from ulp_riscv_vectors.S
void __attribute__((weak)) _ulp_riscv_interrupt_handler(uint32_t q1)
/* Call respective interrupt handlers based on the interrupt status in q1 */
/* Internal Interrupts */
if (q1 & ULP_RISCV_INTERNAL_INTERRUPT) {
// TODO
/* External/Peripheral interrupts */
if (q1 & ULP_RISCV_PERIPHERAL_INTERRUPT) {
/* RTC Peripheral interrupts */
uint32_t cocpu_int_st = READ_PERI_REG(SENS_SAR_COCPU_INT_ST_REG);
if (cocpu_int_st) {
ulp_riscv_handle_rtc_periph_intr(cocpu_int_st);
/* RTC IO interrupts */
uint32_t rtcio_int_st = REG_GET_FIELD(RTC_GPIO_STATUS_REG, RTC_GPIO_STATUS_INT);
if (rtcio_int_st) {
ulp_riscv_handle_rtc_io_intr(rtcio_int_st);
/* TODO: RTC I2C interrupt */
My goal is to differentiate between wakeups due to timer and wakeups due to RTC GPIO changes.
In my ULP main.c file, I've attempted to override the function:
* This function overrides the weak default implementation.
* It is called by the assembly vector code (ulp_riscv_vectors.S)
* https://github.com/espressif/esp-idf/blob/465b159cd8771ffab6be70c7675ecf6705b62649/components/ulp/ulp_riscv/ulp_core/ulp_riscv_interrupt.c#L16
* Default interrupt handler has "// TODO" for timer interrupts which we need.
void _ulp_riscv_interrupt_handler(uint32_t q1) {
ulp_error_flags++; // This is just a random variable I have that I can read from main CPU
What do I have to do to override the original `_ulp_riscv_interrupt_handler`? I've done a fullclean and rebuild.
